Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how much timing at idle for this cam?
Old 10-07-2012, 05:18 PM
Project89 Project89 is online now
Originally Posted by ap72 View Post
a grumpy idle and turbos... You know that usually doesnt mix well, unless you have larger than normal exhaust housings and a good header, even then its usually race only as it leads to reversion issues.
yeah im well aware of it i just could stand the stock like idle of the summit 224 cam any more, the edelbrock came in the engine that wa sin the car when i bought it . so i figured id stick it back in and give it a go and see if its really that bad.
few guys on ttf.com have been able to run some pretty wild tight lsa cams without very many issues so i figure this cam being a good bit tamer might actually just work out pretty good. if not i have the option to reinstall the summit 224 or maybe even try out the sum 234/234
