Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how much timing at idle for this cam?
Old 10-07-2012, 05:22 PM
ap72 ap72 is offline
Banned
Originally Posted by Project89 View Post
yeah im well aware of it i just could stand the stock like idle of the summit 224 cam any more, the edelbrock came in the engine that wa sin the car when i bought it . so i figured id stick it back in and give it a go and see if its really that bad.
few guys on ttf.com have been able to run some pretty wild tight lsa cams without very many issues so i figure this cam being a good bit tamer might actually just work out pretty good. if not i have the option to reinstall the summit 224 or maybe even try out the sum 234/234
Going bigger on the am will not help things, nor will a reverse split.
To run a bigger cam using the parts you have first start with a good turbo header system, and then look into increasing the exhaust housing size. With more overlap exhaust reversion becomes a huge issue a well built header and proper exhaust housing size can greatly eliminate a lot of that.
