Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how much timing at idle for this cam?
  #20 (permalink)
Old 10-13-2012, 10:58 PM
Project89's Avatar
Project89 Project89 is offline
drove the car around a lil more today, had one of my fans stop working so i pulle dover on the side of the road to see what was sup since the engine was getting up around 190* and i ende dup having to push the car backwards to pull out cause somone parked infront of me.
lol really need to get that shifter cable and install it, right now i have the trans stuck in drive so i can atleast drive it around to tune it.
overdrive is a waste below 60/65mph car surges real bad ive tried more timing and less timing and nothing helps , might try adding in some more fuel right now im setup for a lean cruise around 15.5-16.2 afrs
other then that this cam seems to be working well
should work even better if i put the single plane intake and lsx 90mm throttle body, the only reason i havent yet is because the ports are 1206/slightly larger on the single plane heads are much smaller
