how much timing at idle for this cam? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-07-2012, 07:15 PM
F-BIRD'88's Avatar
Yada Yada Yada
You will be much further ahead by concentrating less on what giuy over on this that board is doing or BSing about and work on your own car. There is lots of BS on the boards Especially when it comes to dynos and HP. NO buddy makes 1000 HP with 882 heads. What is it 60psi of boost? and 3 bottle of nitrous oxide?
All you will do is create boost (back pressure) as the air cannot get in or out of the motor with 882 heads on it.
They flow like **** even when fully ported. 100hp less than a camel back or stock vortec or simple entry level perf head on a simple N/A street motor. Give your head a shake. All the blower boost in the world won;t fix a bad cylinder head.
  #17 (permalink)
Old 10-07-2012, 08:01 PM
funny u say that since the car went 11.83@ 132 with a ton of tire spin @ 15 psi witht he summit cam and 882 heads
  #18 (permalink)
Old 10-08-2012, 03:48 PM
got the laptop out and bumped idle timing back to 30* it idles better now , have to change my iac settings though as this cam drives it a lil crazy trying to hold a steady idle.
right now its setup to hold a 850rpm idle , im going to change it so its only active on cold starts once the motor reaches 140* ill have the iac fully close and ill set idle speed witht he adjusting screw on the tb
twin turbo iroc - YouTube
"> twin turbo iroc - YouTube
" type="application/x-shockwave-flash" width="425" height="350">
  #19 (permalink)
Old 10-12-2012, 06:36 PM
well the ole butt dyno says not to bad
spoolup is a tad bit lazy in first gear, but thats actually a good thing in my case, before this thing woudl blow the rear tires right off , now it has a chance to grab some traction at lower rpms
its still pulling pretty damn hard once its in full boost
old cam ='s full boost at 2,800
new cam ='s full boost at 3,600
have some slight low rpm cruise issues to sort out , but im also running a very tight converter right now till i get my 4l80 back
soon as i get a new shifter cable installed on tuesday ill deff get some driving vids posted up
  #20 (permalink)
Old 10-13-2012, 10:58 PM
drove the car around a lil more today, had one of my fans stop working so i pulle dover on the side of the road to see what was sup since the engine was getting up around 190* and i ende dup having to push the car backwards to pull out cause somone parked infront of me.
lol really need to get that shifter cable and install it, right now i have the trans stuck in drive so i can atleast drive it around to tune it.
overdrive is a waste below 60/65mph car surges real bad ive tried more timing and less timing and nothing helps , might try adding in some more fuel right now im setup for a lean cruise around 15.5-16.2 afrs
other then that this cam seems to be working well
should work even better if i put the single plane intake and lsx 90mm throttle body, the only reason i havent yet is because the ports are 1206/slightly larger on the single plane heads are much smaller
  #21 (permalink)
Old 10-13-2012, 11:17 PM
F-BIRD'88's Avatar
Yada Yada Yada
waiting got the time slip from your car.
I bet you cannot get past 108MPH and 13.5ets even with tons of boost, with 882 heads.
They are a cork.
  #22 (permalink)
Old 10-13-2012, 11:30 PM
They are a cork.
no slip from that run, old airport drags, on real tires with traction the car would have gone low low 11's maybe high 10's mph supports that pretty well.
u know u may know a whole lot , but u dont know everything, plenty of boosted cars running these heads well into the 10's/11's without trying to hard on both turbo forums and third gen. for a super cheap budget build they have been proven to make good power with turbos plain and simple
fellow fbody guy with a l98 tpi engine that has been featured in a few magazines has gone low 10's with those heads untouched @ 14/15psi and the 882's are just about even, they do flow better but have crappier chambers.
this aint my first rodeo ive built my fair share of turbo cars
and btw my 3.1L v6 with heads that only flow 125cfm broke 330wheel hp and 420wheel ftlbs @9 psi explain that one
3.1 makes 140hp flywheel stock
grand national heads flow about the same and they routinley make 5-600 hp
Timing / Idle Mac88 Engine 5 08-16-2011 02:53 PM
idle/timing for 383? fireforsin Engine 0 05-29-2006 04:56 PM
timing at idle oldsmo Engine 3 03-20-2005 11:08 AM
timing and idle 5.7jeep Engine 28 11-04-2003 03:21 PM
Rough idle timing 66chevy2ss Engine 6 08-16-2002 12:55 PM
