How much torque can a 700R4 handle? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
  #16 (permalink)
Old 09-29-2011, 06:29 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the problem with the "smart shell" is two fold as I see it. The same design was (or is still) used by a company that called it the "torque drive" shell.
The design still uses a weak OEM drive shell... and where the OEM drums are balanced. That balance process puts small holes (3/8") punched out of the drive shell in the area near the 'fingers' that align with the reverse input drum housing.
Those holes allow the shell to pull apart at that spot under a heavy - power load. I have photos of this if I can find them. I may have to wake up the hamster that powers my old PC
Simply use the 'beast ' drive shell and all seems fine.
found it:
Also the sleeve for the 700r4 type of aluminum drum works well. I have used hundreds of the design. Aluminum pistons do crack. You can cryo treat the drums / pistons or use steel molded rubber piston with aluminum over run piston modified to work with the steel piston
Quick reply to this message
  #17 (permalink)
Old 09-29-2011, 09:57 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
10scnd70, I appreciate the good info.
What are your thoughts on the TH2004R for high performance use? Any advantages or disadvantages compared to the TH700R4/4L60/4L60E? I'm aware of the ratio differences between the two, but is there anything else we should be aware of?
Thanks in advance.
  #18 (permalink)
Old 09-29-2011, 10:56 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by 10scnd70
No you can't use steel forward with aluminum over-run pistone...I've seen quite a few try it and waste the forwards and over-runs. If you read the Sonnax instruction, It specifically states that you can't mix the pistons...
http://www.sonnax.com/system/instruc...733-01K-IN.pdf
Frank
Yes, you can use the steel forward piston with an aluminum over run piston that is modified. Do not tell me I can not, i've done it with out failures.
Remember I've been at this trans thing longer than you. i've built over 200 of the 4L60 trans per yr for years. I have a bit of experience too.
  #19 (permalink)
Old 09-30-2011, 06:19 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
One other item not mentioned here ( If I missed it) The design Sonnax uses here on the aluminum drum was in use years before Sonnax produced their kit.
We used a common t-400 speed-O bullet rubber O-ring on the inside of the machined over run aluminum piston to slide over the steel sleeve on the 700 aluminum drum.
There is also a Speedy Sleeve that can be used with very slight machine work to the over run aluminum piston. Very simple procedure. Speedy sleeve are common use on harmonic balancers worn locations by hard rubber seals
  #20 (permalink)
Old 09-30-2011, 06:11 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Why bother? With the size of your ego , there is only room for one car on the track at a time.
  #21 (permalink)
Old 09-30-2011, 10:03 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
....I'm ranked in the top 5 4L60E builders in the country....
Oh really - Ranked by who?? Show us what you got, surely that came with a huge hat, or something.
Semper Fi
  #22 (permalink)
Old 09-30-2011, 10:40 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Whatever, it's your story, tell it the way you want.
Semper Fi
  #23 (permalink)
Old 10-02-2011, 08:19 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Frank,
I dont fear anything Rossler brings to the table. It is always a good and interesting experience to pull a Rossler product apart. The Coan boys are purty sharp too, nice workmanship.
You like challenges?
Post an "education of 4L60E building" on the forum. Educate me and the forum members on how you build the 4L60e. Not the whole trans, lets pick one area. The 3-4 clutches in the aluminum input drum is a constant failure area for members that visit Hotrodders.com. Show the membership how that drum is modified and built for the power and durability you put into the 4L60e.
The use of thicker regular steel plates to address heat is common knowledge to performance builders. We avoid Kolene steels.
I look forward to your post on that drum and how "Frank" builds, adjusts, sets clearances, modifies it for the power and durability in a low 10 second car. Perhaps related areas on how you get more oil to that drum?
I would also suggest you gather notes for a book if you have not.
  #24 (permalink)
Old 10-02-2011, 11:16 AM
T-bucket23's Avatar
Wiki Edits: 26
What part of I don't have input drum failures don't you understand? I've NEVER had a drum or input shaft failure in anything I've built. Again, this is part of educating yourself and your customer. I find it ironic that you're still doing things backwards. You're using sleeved drums and not Kolene 3-4 steels. You do know you can get Kolene steels in '080", right. Do you need a list of customers that are running in the 9's or 10's to get in touch with you to confirm this? I don't have band failures. I don't have 3-4 c;utch failures, and I've certainly never had an input drum or input shaft failure..Oh wait, back in '08, I had a forward drum that blew the 3'4 snap ruing lugs out after 6 months, because the owner cranked his line pressure up. Read this carefully, again...I"VE NEVER HAD AN INPUT DRUM RIP THE SPLINES OUT! If you'd bother to read all the posts in the forum you moderate, you'd see that I've already explained what causes drum failure. I've got 3700# F-Bodies cutting 1.46 60 ft. times an a 4300# Impala cutting 1.5 60 ft. times with stock drums. I use a standard UNSLEEVED factory input drum. If you're using anything else and you still have drum failures, then you're doing something wrong. The same suspicion I have about your question about the 3-4 clutches. You want to know how I set mine up because you're obviously still having problems gettibng your to live. Do you even know where the 3rd accumulator is on a 4L60E? We'll Give you a few moments to look it up, so you can make everyone here think you do. Are you still using load release springs in the 3-4's? Are you still using a "Corvette" or Sonnax 2 nd servo? Still using factory O'D servos? You still using stock slide springs, in the pump? Still have customers using multi disc converters? Input drums are easy. My only failure point is people breaking output shafts because they don't want to pay $550 for a billet one.
Actually, I was thinking more along the lines of an instructional video, rather than a book. I'll make sure to send you a copy so you can stop breaking input drums and wasting 3'4 clutches...
Frank
Your failure to answer the question would make everyone conclude you dont know the answer to the question.
Chet
  #25 (permalink)
Old 10-02-2011, 12:08 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
It appears Frank is not up to the challenge to 'educate' members here. LOL
Re-read my post Frank, not read "Into" the post what your mind puts there. LOL
Frank, I can walk in to the parts room and pick up thin or thick Kolene steels. I dont use them.
You mention use of Billet servo on the band of the trans. That sorta modifies the 3rd gear accumilator system a bit.
Let me educate you on what I do lately.
Watch this 5 minute video dyno pull Youtube video ... it is the type of power I deal with that past few years. Your 4L60E will not survive that.
LOL Frank , LOL , I dont want or need the spotlite like you. I had mag articles on my stuff in the 1980's, stuff on the covers too. My thought on it now? B F D
Real simple Frank, You joined up here to sell your products since your first few posts included URL and parts sales prices. I edited those items out per the guidelines here setup by Jon the admin guy. You tossed out a fit of anger at me. That is fine Frank.
Now I offered a challenge to you on a simple deal to help the membership here. So far it appears you build a stock 4L60e and use programing to preserve it's life. Which I find interesting since in a different thread you could even answer a base GM programing question a fellow had on speed limiter and shifts to 4th gear at WOT on a Silverado SS truck.
Keep up the good work Frank. Moderators here have already received complaints from membership on your annoying attitude which I am sure you could not care less about.
I pointed out I use aluminum over run piston in the steel molded forward piston. You quote instructions from Sonnax engineers (you seem to dislike engineers)..... Get the parts in front of you Frank. Figure it out like I did. Very simple process, the answer is right in front of you as you look at the pistons.
You may be rated in top five 4L60E builders in the world... you need to work on your personality
  #26 (permalink)
Old 10-02-2011, 01:38 PM
found it:
Crosley, thank-you for answering my question. I think its good to discuss newer/different products as they show up on the market.
What do you like for converters?
I went from a stock Vortec 350/L31 TC to the DCLF V6 converter and get around 2800-2900 brake stall. It has certainly helped to reduce the horrible rpm drop the wide ratio 700/60e/65e 3.06 1st gear and 1.6:1 2nd gears induce. The newer 6l80e/90e's are even worse.
The 700/60e parts appear beefier than the 200r4 parts, but I really do like the 2.75:1 1st and 1.57:1 2nd gearing of the 200r4, esp. when it has to be used with a more streetable non-race converter. Then its got the higher 0.67:1 OD over the 700/60e's 0.70:1, worth around 200rpm at cruise.
Going from 700/60e to th-350's usually drop et's 3-4 tenths around here, but the 60 fts do suffer a tenth or 2.
Thanks again for the info.
peace
Hog
  #27 (permalink)
Old 10-02-2011, 02:22 PM
Originally Posted by Hogg
Ya Bryan's a good guy, you also must be the builder of Pat Gish's 9 second B-body. We have mutual interests in L31 trucks, he has had good results in his truck with his Yank 3600. Bryans L31 tune also works very well on his truck.
I was curious about the Smart shell sinces its so new.
Sounds like you are havuing good luck with the 700/60e's.
Thanks again for all the info.
peace
Hog
I no pat gish. His impala does not run 9's. It runs 11.0's and he made one 10.99 pas at cecil county dragway with me there witnessimg it.
  #28 (permalink)
Old 10-02-2011, 03:54 PM
WOW! You've got a picture of you and William launching together. 2 of my 4L60E's Thanks, Alex. BTW, I've built quite a few 4L60E's for your group up there and friends in Baltimore. Ever hear of a single one of my '60E's breaking an input drum? Or wasting 3-4 frictions? Or 2-4 band failure? After 3 years, your's broke a hardened 4L65E shaft, but the 3-4's and band still looked like new. Now, with the billet output shaft, we've eliminated that weak point.
Frank
Out of about 15 people i know with ur transmission, we have only had two failures. That is mine with the broken output shaft after 3 years, and the wagon who broke the input sprag when he busted the rear at the starting line. And sum of these guys are going on 5 years like all the d.c. Bbody guys.
  #29 (permalink)
Old 10-02-2011, 03:56 PM
And again i didnt come in here to back frank up or anything like that. I simply came in cuz he asked can he post a pic of my car so i checked the thread out after and i wanted to write in to let u guys im not a made up person!!
  #30 (permalink)
Old 10-02-2011, 09:24 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Frank
You're so surprised!! Do you think we're stupid?? You bring in a shill, who btw street races? Nice. Totally grade school stuff, with the adolescent ego to match. You've got to be kidding, lol.
Semper Fi
Closed Thread
700r4 torque specs praevalesco Hotrodding Basics 0 04-24-2011 09:55 AM
custom build transmission to handle 5000 pounds of torque? kkuzmicki14 Transmission - Rearend 4 02-14-2010 10:37 AM
700r4 Torque converter retiredmodman Transmission - Rearend 2 03-29-2009 10:14 PM
700r4 torque convertor 455c-10 Transmission - Rearend 13 09-06-2005 01:28 PM
700R4 torque converter HURSTW25 Transmission - Rearend 3 09-28-2004 07:07 PM
