How much vacuum does a modulator need? TH350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2012, 11:51 AM
6426yy's Avatar
Im pulling about 10 pounds is this enough? Thanks
Old 03-13-2012, 05:01 PM
modulator vac.
That should be plenty.
Old 03-13-2012, 07:42 PM
tnsmith10's Avatar
when will it rain???
with that low of vacuum, i recommend a modulator with a black stripe. its for low vacuum.
vacuum modulator yragat Transmission - Rearend 1 02-04-2011 03:52 PM
Th-350 vacuum modulator monzter Transmission - Rearend 12 09-01-2010 10:48 AM
th350 vacuum modulator user_name Transmission - Rearend 3 04-21-2006 08:19 AM
Do I need the vacuum modulator? 65 streeter Transmission - Rearend 4 07-04-2004 02:03 PM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 02:25 PM
