How much will the diff take? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2008, 05:59 PM
"70" Cougar's Avatar
Meat-Head Extroidenaire
How much will my 9 inch take?
70 cougar 9inch 3.55 gears new detroit no spin locker. stock 28 spline axles new pinion support ( purple anodized) works awesome! I make approx 420 hp/tq. I plan to put drag radials ( as big as my stock wheel well will allow,not sure what that is) right now i have 255 75? 15. Im sure i'll have to go to after market axles.I plan on making 450 to 500 hp/tq tops in the future. My question is will after market 28 spline axles take it? Ive been told no from Hotrods n classics. But the guy that built it last year said yes. What are your opinions. I just wanna stay away from having to buy another locker that will accept 31 or 33 splines. But in the end if i must i must.
thanks for any help people
Bill
Old 01-11-2008, 07:34 PM
they want take the burn out's to well .
when you come out of the wet and hit the the dry ,
it won't last long .
can you get 31 spline idler gears for them set ups from strange or mosier ?
jeg's or summit maybe ?
Old 01-11-2008, 08:13 PM
When you say " idler gears" do you mean the gears on the side of the locker... cause if so, thats awesome! I wondered if they could be changed or not. Ill look it up some more thanks Burnt Olds.
bill C
65 posi diff. popa60 Transmission - Rearend 2 09-08-2006 01:05 PM
Replacing Rear Diff Pinion Seal...question??? Frankoholic78 Transmission - Rearend 13 05-25-2006 06:09 AM
Need a little more Diff. help??? gwstang Transmission - Rearend 5 11-15-2005 08:37 AM
GM 10 bolt Diff ID numbers? Gearhead forever Transmission - Rearend 8 04-27-2005 08:45 AM
posi diff identification sportsman69 Transmission - Rearend 3 10-30-2004 09:44 AM
