how much will stock rods and crank take? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2002, 05:25 PM
nastynova's Avatar
Question how much will stock rods and crank take?
I'm building a new motor using a one piece rear main seal block and crank...I've been told that the stock crank and rods will be fine, don't worry about it...and I've been told the opposite...I will be using main studs (2 bolt) and ARP rod bolts, and it will be balanced....11.5-12 to one compression ratio...will it work or grenade on me????
Thanks
Nasty
Old 12-29-2002, 05:41 PM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
Cool
I'm running a GM Block, Crank and Heads on my Blown Alcohol injected engine. 1,000 HP. Have aftermarket rods, pistons and valve train.
Old 12-29-2002, 06:02 PM
Post
depends what your setup is, and how fast you plan on spinning it... i seem to remember stock is fine up to 500 hp or a little over, and maybe 7+grand if balanced. on the other hand, take a survey here 'cause for every person here you've got 2 or 3 opinions.
my $.02
-z-
Old 12-29-2002, 06:03 PM
nastynova's Avatar
Post
stock crank???
do you know where i can find out a rough idea of what this motor will put out?
Old 12-29-2002, 06:38 PM
Post
you could get a rough idea from a desk top dyno. He is right on the rods and crank holding around 500hp and taking 7grand. but it's risky. you can get a set of good rods from naparts.com for $220 it's worth the peace of mind.
Old 12-29-2002, 06:54 PM
Infomaniac's Avatar
Post
[quote]Originally posted by nastynova:
<strong>stock crank???
do you know where i can find out a rough idea of what this motor will put out?</strong><hr></blockquote>
502 Gev IV Good stuff.
I mentioned that because it is 1 piece rear main.
The small block stuff is good for about 500 HP and we run limited class sprint car stuff to high 7K RPM's every weekend. 13:1 compression alcohol 2bbl classes. Stock crank and block
[ December 29, 2002: Message edited by: Infomaniac ]</p>
Old 12-29-2002, 08:11 PM
Post
def. have the crank and rods magnafluxed, if you decide to stick with them... and post the details of your setup on here, someone can definitely give you a hp figure with more info on heads, intake, cam, and carb
happy rodding!
-z-
[ January 02, 2003: Message edited by: steppenwolf ]</p>
Old 12-30-2002, 05:03 PM
nastynova's Avatar
Post
Thanks guys...
what I plan to run....
350 30 over
holley 650 DP w/proform body
victor vortec intake
vortec ported and polished heads (cast) w/manley race flow valves
keith black KB-180 pistons (11.5 to 12.0 compression) race gas
edelbrock torker cam (for now)
electric fuel and water pumps
windage tray
[ December 30, 2002: Message edited by: nastynova ]
[ December 30, 2002: Message edited by: nastynova ]</p>
