How much would you charge? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 05-20-2012, 02:08 PM
What kind of machine do you use? Also, is this all vinyl? Do you use some foam or headliner material backing on the covered door panels and dashes?
  #32 (permalink)
Old 05-20-2012, 02:43 PM
crsweet91's Avatar
Machine is a singer 111. I use 1/8" landau foam for my panels and tops of dashes. Everything Ive done so far is vinyl, except for that steering wheel.
  #33 (permalink)
Old 05-20-2012, 04:17 PM
Awesome. Those stitches are laser straight!
  #34 (permalink)
Old 05-20-2012, 06:50 PM
Last journal entry: Getting Started with Upholstery
It would be cool to see a few under construction photos of your door panel. I like it!
  #35 (permalink)
Old 06-06-2012, 09:23 PM
crsweet91's Avatar
Still doing a lot of dashes and my french seams are pretty straight, but its hard to get these really long ones perfect. I read recently about a guy using a double needle machine to get perfect seams. Since I do a lot of french seams I figured thats a great idea. I could get perfect seams and cut down on time. He pulls one needle out for regular seams, but Ill still keep my single needle one.
Whats a good double needle machine. Im looking to pick up a used one.
  #36 (permalink)
Old 06-07-2012, 08:10 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Singer 212W is a good double needle machine. The problem with double needle machines is that they only do one width of seam. If the machine is set up for 1/2" between the stitch lines, that's all you can do unless you change a bunch of parts. They also do not make different feet for them, so if you want to sew a welt, it's not possible.
  #37 (permalink)
Old 06-07-2012, 07:26 PM
crsweet91's Avatar
Thanks for that info. Thats one of the answers I was looking for, regarding the needle spacing. If I can find one that has the spacing Im looking for, it would work out. Im still planning on keeping my singer 111. I just think that with all the french seams I do it would be smarter, faster, and I would get a better seam. Mainly what I want is just a better, higher quality seam. Im a perfectionist and that type of stuff bothers the hell out of me.
  #38 (permalink)
Old 06-20-2012, 09:44 AM
crsweet91's Avatar
So I did a set of visors And compared them. One set without those little metal chrome clips to finish off the stitching, and one set with. I personally like them with the clips. Where can I buy these from? Theres gotta be somewhere where I can pickup a box of them. Tried searching but had no luck, maybe Im not calling them by the right name. Any helps appreciated. Thanks
  #39 (permalink)
Old 06-20-2012, 10:36 AM
Wiki Edits: 22
You would think that stuff like that would be easy to find, wouldn't you? The first problem is what are they called, which is sun visor binding tips. The only place I've seen them for sale by themselves is LeBaron Bonney.CLICK HERE These are the ones with the closed ends.
  #40 (permalink)
Old 06-20-2012, 10:42 AM
crsweet91's Avatar
Well thats frustrating. I want the straight ones not corner ones. I thought for sure someone would sell boxes of them, like the clips. auveco doesnt sell any?
Looks like Ill be doing some searching tonight. If I find any Ill post the link.
  #41 (permalink)
Old 06-20-2012, 11:34 AM
crsweet91's Avatar
I found these. Looks like they might work, just need to be tweaked a little with some needle nose. Called nalclips, made for holding paper together, but same idea as a visor. I think theyre stainless too.
found them in this guys blog thing.
http://electricvogue.blogspot.com/20...1_archive.html
Heres a link to office works, not sure what size would be best, might have to buy a couple different sizes and test them out.
http://www.officeworks.com.au/retail...and-Dispensers
  #42 (permalink)
Old 06-20-2012, 11:40 AM
Wiki Edits: 22
No, Au Ve Co doesn't have them. They have the little welt tips, but not the sun visor binding clips. I've looked for them before, and came up empty other than LeBaron Bonney.
  #43 (permalink)
Old 06-22-2012, 11:28 PM
crsweet91's Avatar
I think that nalclip thing was a stupid idea, I failed to notice that I think theyre only sold in Australia, probably wouldnt have worked anyways, was just an idea. This visor binding clip is driving me crazy.
Have you tried this company to see if theyll sell clips to you. They have the straight ones I want. Ill send them an email.
http://www.autosunvisors.com/restoration.htm
  #44 (permalink)
Old 06-28-2012, 10:41 PM
crsweet91's Avatar
So I gave up on those visor binding clips, that one sunvisor company sells them, but for $17 a set. No way Im spending that for those unless I really need them.
Did a couple more visors and was doing a dash pad today. I like to do all my top stitching with 138, but I think Ive finally realized my singer 111 doesnt consistantly sew 138 nice. Its been a pain to get the tension right when using that size, even when I think I have it right I get these inconsistent sections of really bad stitches, and Ill even get my top thread shredded sometimes. Ill spend hours trying to get it setup, but I still cant ever get it perfect. Ive basically tried everything.
So I did one set in 138 came out OK, but the stitches werent as nice as I like. Switched over to 92 on another set and it flew through them flawlessly. Am I right on this or am I just not setting up the machine right for 138? What are some good machines I can pick up used that can sew the larger thread real easy, Id like to be able to sew up to 270.
Heres the ones I did in 92 and they came out perfect.
  #45 (permalink)
Old 06-29-2012, 07:12 AM
Wiki Edits: 22
What size needle are you using? Also, run the top thread straight through the thread guide on the top of the machine, like in the first picture. My sewing machine mechanic told me to do that with larger thread, but my Consew 226 with a size 22 needle sews fine with 138 with the thread run through the top guide like in the second picture.
If you want to sew with size 270, you need a machine with a larger bobbin, or you'll be changing bobbins every two minutes.
ID:	66435   Click image for larger version
no charge weekend warrior Electrical 1 10-05-2010 11:15 AM
How much do I charge? Faux King Painter Body - Exterior 2 09-04-2006 01:29 PM
Super charge/Turbo charge Meka Engine 8 11-24-2003 06:33 PM
Turbo charge or super charge for a small block olds Andrew7dg Engine 2 11-12-2002 11:23 AM
no charge! deitwob Electrical 2 06-16-2002 06:46 PM
