tick-it-a tick-it-a tick-it-a. If you don't get a woody from that idle, there's something wrong with you There's nothing like that tick-it-a idle from a hot Poncho. Let us know how it sounds.
Sounds like a good setup but before you fire it make sure that you cna get some racing fuel as your compresion ratio is going to be extremely high with those heads. Right at 11.5-11.8-1. The gears may be a little steep but should be a good performer. This is a very heavy car and is going to take alot of torque to get it moving. Let us know how it turns out.
With 72cc heads if flattops are used the compression will be in the range I specified. Even if the pistons are dished the compression will still be above 10:1 which is too high for pump gas in a Pontiac. 9.5:1 max for a Pontiac pump gas street engine. The 3.73 gear is a little steep for a 455 as 3.55's are a better gear and keep the 455 in the lower rpm range it was orginally designed for, even in such a heavy car as a GP, maximum rpm should be kept at 5200 unless forged or aftermarket rods are used. Then maximum rpm would still be limited to 5800 as the 455 has increased rotating mass due to the 3.25 main size. There are a lot more variables when building Pontiac engines that have to be taken into consideration before building can begin, much unlike a SBC. The 455 Pontiac is a low rpm torque engine and with the large main size is very limited on rpm. 85cc Edelbrocks would have been a better choice and would have put the compression at 9.5:1 and still make for an extremely strong engine. Also the 455 will make excellent power with a slightly smaller cam that would operate in a lower rpm range. If this is to be a strictly street driven engine you won't be happy with it as I referred before you will need racing fuel for this engine.
I almost forgot with the 1.65 ratio HS rockers your total valve lift is going to be .557 on the intake and .560 on the exhaust. How were your springs set up as far how much lift they can handle and what is the coil bind?
The rods are custom H beam rods. The pistons are custom forged cut for 10:1 compression. I have oversized valve springs. You can see the pics at the following address.....
My friend has a very similar combo in his 70 LeMans, but with a slightly smaller Comp XE cam and 3.23 gears, and it's pretty hot. He hasn't run it at the track yet but its fast all right.
Sorry it took so long to get back to you guys but I finally got a video posted with the car running....This was a video from the first 20mins of starting up. Tell me what you guys think
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
