How to narrow a 10 bolt rear differential? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2011, 03:33 PM
I want to narrow a 10 bolt chevy rear. any suggestions?
Old 02-26-2011, 03:35 PM
Crosley's Avatar
Wiki Edits: 1659
Read this article very closely:
clik here
Old 02-26-2011, 03:46 PM
big gear head's Avatar
High Performance Rear Ends
You must have a housing fixture to do this. If you don't then you are taking a chance of ruining the axles and differential because of misalignment. You also must have very good welding skils. I've narrowed more than 100 rear ends and I have all of the special tools for the job. I've seen people try to use shortcuts to do this and the results are usually pretty bad.
how do i narrow my rear end? the nitro man Suspension - Brakes - Steering 1 06-02-2009 11:46 AM
$$$ to narrow 10 bolt ? Vortech 4.3 Transmission - Rearend 8 09-07-2007 05:35 PM
Mini tub, narrow rear first or buy wheels first? CHASINGJR Transmission - Rearend 3 09-20-2006 11:21 AM
What is the most narrow rear end malibu68 Transmission - Rearend 8 06-23-2006 07:34 AM
What's it cost to narrow a GM 10 bolt 8.5" BradZ28 Transmission - Rearend 4 10-30-2002 07:54 PM
