How not to freeze - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2009, 10:43 PM
awert's Avatar
58/58
How not to freeze
what can i use in my horizontal saw for a cutting/cooling lube that won't freeze on me this winter. It has a 5 gal. coolant tank, I almost bought some cutting/cooling fluid that you mix with water, but the guy didn't know anything about it's anti-freeze-up characteristics. This holds 5 gallons/ located in Mn.
Old 10-03-2009, 11:34 PM
kleen56's Avatar
Living in CA, when it hit 50 degrees we call that freezing. I know several friends of mine in the cold areas use a synthetic fluid. Here is what they are using. Hope this helps.
http://www.grizzly.com/products/H9238
Old 10-04-2009, 06:54 AM
BOBCRMAN@aol.com's Avatar
I use RV antifreeze (alcohol) in my crank grinder. Some soluble oils will get gummy tho.
Old 10-12-2009, 02:58 AM
Just a thought...since you've already got an appropriate lube for the saw and you just want it to stay liquid and suitable for lubrication purposes.
Hit up a feed store or farm supply for a water trough heater. It's like a fish tank heater, but made bigger to keep large (100's of gallons) farm sized water troughs from freezing in the winter. It should work to keep your coolant/lubricant warm enough to lube the saw in the wintertime.
Old 10-13-2009, 05:31 PM
Last journal entry: frame build
Put a heavy duty truck type battery heater or two on the tank. Works well and shuts itself off when not needed.
Old 10-13-2009, 07:46 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
We have a big band saw with the coolant tank and had the same concerns. We just use the cheapest anti freeze we can buy and mix at a 50-50 mix. We have been using it for quite a few years now with no problem.
Old 10-14-2009, 01:27 AM
4 Jaw Chuck's Avatar
I use Varsol, its universal and cheap...leaves a nice clean cut too. Probably the best cutting lubricant you can use in a bandsaw especially for aluminum.
Give it a try.
— Han Solo
Freeze Plug problem Fergusonic Engine 19 05-23-2009 08:22 PM
DO THEY MAKE "CYLINDER HEAD BRASS FREEZE PLUGS ? SCHOONER Engine 12 02-05-2009 08:28 PM
Freeze plug problems Neios Engine 4 10-30-2007 06:44 PM
Freeze Plugs..... 1Fast65Elky Engine 29 02-22-2006 06:57 PM
Freeze Plug Installation (too Far?) Teejay68 Engine 2 07-24-2005 08:38 PM
