-   Hotrodders' Lounge (http://www.hotrodders.com/forum/hotrodders-lounge/)
-   -   How to old school a suicide front end on a 32' Ford (http://www.hotrodders.com/forum/how-old-school-suicide-front-end-32-ford-48288.html)
teched 09-22-2004 08:19 AM
I just picked up a 32 AA truck from a friend. Since the frame is so beefy and the body pretty rough I thought it would make a good rat rod project. I would like to know how to set up a suicide front end that will allow me to get the front as low as possible, using a stock front axle and stock radius rods(not hairpins). Any old school tricks would be greatly appreciated.
bowtiebabe72 09-22-2004 08:24 AM
You would probably get a better response to this question in one of the tech forums on this board.
willys36@aol.com 09-22-2004 09:07 AM
Been discussed her already.
http://hotrodders.com/showthread.php...hlight=suicide
If you want to do a rat rod, proper way is to split the stock Ford wishbone and attach it to the frame rails, weld a plate out front of the frame with a couple of gussets and bolt on the axle. Suspension will bind a little but not intolerable and authentic. If you want better action, go with 4-bar links but that ain't rat! See photos in car mags or shoot some at a rod runs for the details.
http://www.rodshop.com.au/photos/tfrontend.jpg
