How to old school a suicide front end on a 32' Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2004, 08:19 AM
teched's Avatar
New Member
Last journal entry: Z'd Frame
I just picked up a 32 AA truck from a friend. Since the frame is so beefy and the body pretty rough I thought it would make a good rat rod project. I would like to know how to set up a suicide front end that will allow me to get the front as low as possible, using a stock front axle and stock radius rods(not hairpins). Any old school tricks would be greatly appreciated.
Old 09-22-2004, 08:24 AM
bowtiebabe72's Avatar
Microwaving kitties? bad!
You would probably get a better response to this question in one of the tech forums on this board.
Old 09-22-2004, 09:07 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Been discussed her already.
http://hotrodders.com/showthread.php...hlight=suicide
If you want to do a rat rod, proper way is to split the stock Ford wishbone and attach it to the frame rails, weld a plate out front of the frame with a couple of gussets and bolt on the axle. Suspension will bind a little but not intolerable and authentic. If you want better action, go with 4-bar links but that ain't rat! See photos in car mags or shoot some at a rod runs for the details.
http://www.rodshop.com.au/photos/tfrontend.jpg
