how old is too old for valve springs?
my heads were on an engine in storage with the rocker arms still tight for 25 years. water got in the intake and they have already been redone. but the guy said the springs were okay and re used them all, they never got rusty, but still they have had tension on some of them for 25 years. in my opinion they must be junk, and he should have changed them. this is on a relatively low revving (below 6000) pontiyack motor. your thoughts?
Did he check them all for pressure/installed height and pressure at max Lift?
If you are buying a new cam, springs are cheap verses ...
Fact is stranger than Fiction |
HE said he checked a couple and they were fine. i never told him about the motor being in storage!!!
![]() i think i know where this is going......... |
They all need checked on an individual basis. It only takes one weak spring to ruin your day.
I would have them dissasembled and checked, properly. Then make a decision. If they are good
You would need to check them all the ones that were down may be weak. But still able to run for a while but as the miles tick by they will also be the first to fail. |
Every time you shut your engine off the springs sit at different tensions, so if your engine has enough idle time over the years it's going to have a lot of time with compressed valve springs. The big thing is to check every one, not just random springs. If they all check out, then years of sitting or running doesn't matter.
Thanks, will have to read up on checking them, as I can install and chech bhramaputra. But not pressure.
| Will These Valve Springs Work With Vortec Valve Spring Seats | ChevroletSS | Engine | 8 | 11-26-2012 02:56 PM |
| valve guide cutting, dual valve springs | ekacpuc | Engine | 3 | 08-12-2011 06:39 AM |
| differnce in valve springs. will flat tappet springs work with a roller cam? | hemiguy2009 | Engine | 1 | 01-31-2011 03:19 PM |
| valve springs | derek32303 | Engine | 5 | 02-15-2006 10:40 AM |
| Can the dual coil valve springs on a BB destroy Valve guide seals | Auto-Part | Engine | 4 | 11-25-2003 05:23 PM |
