How to "one-wire" alternator? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2006, 10:30 PM
dpjmw's Avatar
I'm going to buy one of those one-wire alternators for my old camaro. 2 questions.... 1) Where do you hook up the one wire from the alternator? to the celenoid? 2) can I remove the voltage old regulator from the car?
Old 08-19-2006, 11:07 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Just run a 8 gauge wire to the battery make sure to use a fuse link. And yes you can lose the old regulator. The 1 wire alt has a self exciting regulator built in. Just start the engine and tap the gas thats all there is to it! IMHO I think the GM 10si one wire alt is the best all around alt made.
Old 08-20-2006, 01:20 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Only thing I could add to that is be sure to install a Fuse link on that line..
From the Battery Terminal on the Solenoid, to a fuse link (or maxi Fuse) To the Alternator. And a 10 gauge wire from the Alternator Ground lug back to GROUND near the Starter..It's all good!
Doc
another frustrating alternator problem darom Electrical 13 04-09-2006 11:09 AM
alternator wire hanging in mid air?! pcoghlan Electrical 11 03-21-2006 02:47 PM
alternator problems woodmanscott@hotmail Electrical 7 01-18-2006 05:06 AM
New Powermaster alternator, broken? arch Electrical 2 06-12-2004 10:38 PM
one wire / three wire, alternator hookup 65truck Electrical 1 10-24-2003 03:59 AM
