How to paint an engine block to match vehicle - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2009, 07:39 PM
Hey fellas. im normally in the engine forum but had a quick q about some paint. Im in the middle of a project and was wondering how yall paint the engine to match the vehicle. I used a urethane paint on the vehicle and was wondering if i could also use this paint on the block or is it a certain paint i need and jus try to match to color? any info would be appreciated, Thanks.
Old 04-10-2009, 08:14 PM
350cruiser,
Clean the engine and use the same paint.
Scholman
Old 04-10-2009, 08:33 PM
302 Z28's Avatar
Use the urethane that you are using on the body, it is far more durable than anything else you could buy to paint the engine. The engine heat will not affect it.
Vince
Old 04-10-2009, 10:19 PM
hey guys i appreciate it. I wasnt sure if the paint would work with the heat or not but i guess so. Thanks.
Old 04-11-2009, 06:54 AM
modern Urethane BC/CC or SS is the most durable engine paint as has been mentioned... Go for it...
Paint does not match rebelbill1972 Body - Exterior 18 04-20-2007 08:01 PM
Engine Paint vs Header Paint Canadian Charlie Engine 4 02-18-2007 10:42 AM
emision loopholes digitalfrek Engine 13 03-13-2006 06:25 PM
engine paint? scheetz93 Engine 1 04-20-2005 09:08 PM
How Do I Match The Paint???? Jim Weeks Body - Exterior 2 06-28-2002 10:54 PM
