How to pick a camshaft/duration/lift - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2012, 11:14 AM
Hello:
I see quite a few posts where people ask: "what cam should I pick?"
Well, here is an article that I found on 3rd Gen.org to help the new person pick a camshaft and understand more what they are doing...Perhaps this will help on your next build for your car/truck. Hope this helps and it is easy reading and easy to understand.
http://www.thirdgen.org/sbc-camshafts-primer
Old 03-28-2012, 12:11 PM
Old 03-28-2012, 11:03 PM
Originally Posted by Catfish11
Thanks CatFish 11~!
Old 03-29-2012, 09:23 AM
This link should help. A lot of good info at the compcams site. Also check out their camquest cam selector tool.
http://www.compcams.com/Pages/413/ca...ion-angle.aspx
bt
Old 03-29-2012, 05:25 PM
bt
I was looking at the dyno graphs of a couple of cams Comp used to get a guesstimate of torque and hp with the cam combination I am using...Should be close to 420 torque and 360hp...Good nuf for me with my mild build.
Thanks for adding the great information from their site~!
Cam duration vs. Cam lift tuff82 Engine 2 08-04-2010 01:16 PM
lift and duration on 305 cam southernboy1015 Engine 3 05-28-2010 12:00 PM
Solid Camshaft lift and duration changes...fusterated 357cutlass Engine 21 04-13-2009 01:02 PM
Cam lift and duration? BMM Hotrodding Basics 1 07-23-2006 01:55 PM
lift and duration? akm Engine 7 08-23-2003 09:12 AM
