how to pics of model a coupe floor - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2011, 09:55 AM
i need some ideas of new floor in my 30 coupe. tore the old crappy floor out and don't know how to do it the best way.really need some visuals. thanks davey nuts&bolts
Old 07-26-2011, 11:43 AM
Fairly easy and straight forward process.
You might like looking at the build process photos here
http://www.hotrodders.com/forum/jour...ge=1&reverse=1
Old 07-26-2011, 12:29 PM
cboy's Avatar
Last journal entry: Finished
These are from a scratch-built rather than an actual Model A so may not be as helpful as Deuce's pics, but might give you some ideas to work from. More detail and pics here or here.
Always learning...and sharing what I've learned.
Old 07-26-2011, 12:53 PM
Irelands child's Avatar
If the original body cross members are in place, you can just make filler pieces and either bolt or weld them in place - the originals were riveted down. You can also just skin over those cross members with individual pieces too. Then the trunk/or rumble - if it's a trunk, a flat floor the same as the pass. compartment will work. If it's going to be a useable rumble seat, then you have to make up an angled riser to bolt the seat to. I wasn't happy with what Brookville Roadster provided though they are replica's of the originals so I made up replacement filler pieces with a reinforcing grid between a top and bottom panel. That grid is used for seat bolting as well as the seat belt anchors.
I 'lost' my floor board photos
Dave W
Irelands child
30 ford coupe front floor bill plise Body - Exterior 2 01-14-2010 11:24 PM
30 coupe floor bill plise Body - Exterior 1 12-30-2009 12:13 AM
30 coupe ft floor william r plise Body - Exterior 1 04-20-2009 08:41 PM
Model A number on floor support 29modela Hotrodding Basics 2 03-16-2005 03:45 AM
possible pics on floor work rosscone Hotrodders' Lounge 0 11-26-2004 02:15 PM
