How to plumb a gas powered air compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2011, 08:06 AM
I would like to have a detailed drawing on how to plumb a gas powered air compressor. I want to fix me a gas powered air compressor when the tank reaches the set air pressure the gas engine will still run with some type of relief valve to operate the points so the air pressure will be regulated to cut on and off. Please help me with this project.
Thanks, Don Swain
Old 09-04-2011, 09:06 AM
Wiki Edits: 27
constant run compressor.
Both my electric and gasoline twin cyl-twin tank wheelbarrow CONSTRUCTION compressors are constant run and have the valving factory equipped. The electric ones are constant run since the compressors have high starting loads and most construction temporary power setups or generators can't handle high spike loads, With the slow down in construction it's probably easier and cheaper to find a good used one. I haven't had to use the gasoline one for a while and after it has been in storage I have to use wd 40 on the valving control to lube it up to get it working properly. My step son gave me a 3 phase 440 V 10 HP 2 stage 80 gallon tank compressor the oil Co he works for replaced with a new one. I have thought about changing it to a gasoline power for the shop or getting a 3 phase converter, BUT it's still setting on the pallet.
Old 09-04-2011, 09:37 PM
47dodge's Avatar
Last journal entry: 1947 dodge
Are you trying to repair one or build a new one. if you are building one it is cheaper to look for a used one Craigs list than to build. I had several hundred dollars into building mine and I already had the motor and pump. when I sold the truck it was on I got one for $150 on craigs list. If you still want to build one you will need an Unloader Valve, a check valve to keep all the air in the tank when the unloader opens, a safety valve in the tank to keep the tank from blowing up if the unloader fails, and a throttle control. I can point you to those if you need them
gas powered compressor pump matt167 Garage - Tools 47 12-10-2011 06:55 PM
How to Plumb Gas line to tank w/ 1/2" obengston Engine 8 11-17-2010 06:47 AM
Air powered or battery powered nailer? HotRodMan Garage - Tools 4 07-26-2010 07:09 AM
building a gas powered air compressor 47dodge Garage - Tools 18 07-13-2008 04:49 PM
If you thought I was a bubble offa' plumb before.......... Hippie Hotrodders' Lounge 7 05-05-2008 07:32 AM
