how to Pressurize a cylinder with compressed air
How can I how to Pressurize a cylinder with compressed air?
Tried the hose for my compression tester but air will floow through it to cylinder, must have a check valve or one way type valve any ideas |
You do realize that in order to pressurize the cylinder, both the intake and exhaust valves on that cylinder have to be closed ... right?
SHould have started at beginning
I did this see below, and was told to remove rocker arms and fill cylinder with air and listen for leaks but cant get and air into cylinder to listen for leaks I am thinking that I have to ahve bent valves but trying to be sure before tear down, or am I wasting time? Should I jsut go ahead and remove heads? I am getting the idea for all info that bent vavles are probably the problem since it will run badly on two cylinders> Thanks Timing chain broke while driving Replaced timing chain, on 1992 Dakota, book said to bring #4 cylinder to TDC compression did that, truck runs but only has compression of 120 on 2 out out of 6 cyls, #4 and #5 has compression Took valve cover off pass side and cranked and seen all rockers moving etc Any ideas why no compression on 4 cyls? Do I need to star removing heads to investigate? Any ideas appreciated |
Get a different book! Bring #1 to TDC on the compression stroke. Install the gears and chain, aligning the timing marks to the centerline. ![]() Autozone Repair Guide |
| water in compressed air, what do i need? | 406 ss monte | Garage - Tools | 3 | 02-07-2010 09:51 PM |
| pressurize intake manifold | GMR | Engine | 11 | 01-13-2009 07:10 AM |
| Air compressed car. | Rob Keller | Hotrodders' Lounge | 4 | 02-01-2008 10:47 PM |
| Compressed Air Question | DONZIE | Body - Exterior | 15 | 10-05-2006 06:05 PM |
| Compressed Air Filter | Irelands child | Body - Exterior | 1 | 09-13-2006 04:53 PM |
