Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to::: Priming An Engine
Old 11-15-2012, 04:25 PM
delawarebill's Avatar
delawarebill delawarebill is offline
Priming
as rich said.. i changed my cam a few months ago and got the same as u mentioned.. most got oil some didn't.. after turning the engine i got oil everywhere.. but u really need to pay attention where the motor is and after u turn it.. as i mentioned above.. you'll end up at TDC or BDC.. that'll put the dizzy correct or 180 out.. if your running a 350 chebby and the timing marks are 6 and 12 then the dizzy needs to be put in with #6 firing. one full turn point it to #1 cyl.
