how to properly measure the lift of a cam ? NOW WITH A MULTIPLE CHOICE POLL!!! - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: measuring cam lift
follow the diagram and you will get the proper lift value 4 50.00%
following that diagram will NOT tell you the lift of a cam 1 12.50%
the rest of the valve train has everything to do w/ lift @ the cam 1 12.50%
the rest of the valve train has NOTHING to do w/ lift @ the cam 4 50.00%
camshaft lift doesnt exist on DOHC cars, only pushrods cause lift 0 0%
Multiple Choice Poll. Voters: 8. You may not vote on this poll
Old 10-01-2007, 09:48 PM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
ok, this debate keeps going on a different forum, the threads even been locked and im getting private messages and even messages through aol debating weather or not im right
simple problem:
a friend went to purchase some reground cams
he measured base circle
he measured overall lobe height
he did some simple math
simple match says LESS LIFT THEN STOCK
the cam was measured in this fashion:
is there any possible way that you can do a-b=c and have a not be the actual lift on the camshaft?
the only reason i can think of is that the cams TOTAL duration is high enough that it interferes with measuring base circle (which definantly doesnt apply in this case)
a variation of this reason is that the person that did the measurements is incapable of operating a set of dial calipers (causing him to accidentaly include one of the ramps in his attempt at measuring the base circle) but said person in this case has machine shop quality control experience
Old 10-01-2007, 09:50 PM
MI2600's Avatar
Member# 3287
Yes, c-b=a.
Old 10-01-2007, 09:52 PM
Jmark's Avatar
is there any possible way that you can do c-b=a and have a not be the actual lift on the camshaft?
IF the ramps do NOT interfere with the measurements, I see no problem with how you did it.
Personally, I'd use a dial indicator on the lobe and rotate it through one full turn and note the minimum and maximum readings, then subtract. But in your case with a fairly stock cam, yours should be fine!
Mark
BTW.....very important thing here that should not be overlooked.........DON"T BUY A REGROUND CAMSHAFT!!! LOL
Old 10-01-2007, 10:11 PM
Wiki Edits: 22
they were cams for a niche market vehical, noone makes new cams, the only options are regrinds or find someone to make a single set of custom billet cams
on a DOHC v6, that seams to be about $1200. or the other option for this car is $550 for a set of already proven regrinds ... and in this case we were considering buying what was said to be one of those sets of regrinds, slightly used, for $250
almost a grand in savings is hard to say no to (except when the specs show that said used cams dont meet the regrind specs, lol)
Old 10-01-2007, 10:28 PM
measure lift of cam lobe
I missed something.
the simple math formula is wrong.
to get lobe height you subtract b from a to get lobe height.
A-B=C
Bear
Old 10-01-2007, 10:50 PM
Wiki Edits: 22
^^^ nope, your not missing anything, i jumbled the letters somehow, lol
fixed in my original post now, but luckily i had the other description right above the image, removing some of the confusion
Old 10-02-2007, 07:30 AM
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
building a 1935 5 window coupe gunnulf Hotrodding Basics 8 06-28-2006 06:43 PM
calculate cam lobe lift? davedeltadog Engine 3 01-10-2006 01:55 PM
Olds 350 help, 2 dead cylinders & cam lift Q? 360Camaro Engine 35 07-10-2005 02:42 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
