How to PROPERLY polish crankshaft journals yourself? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-30-2010, 04:54 PM
Wow thanks for all the suggestions guys....... I guess I should have explained the situation and reason for doing this in my original post. The crankshaft only has about 1000 kilometers on it (pistons detonated) and all journals look fine I was just wanting to remove the "stain" left on them from the bearings. I will be mic'ing each journal to verify the measurements but with that little usage and visual appeal being good I am assuming I won't find anything out of the ordinary. I just wanted to "shine them up" before I rebuild this engine, I wasn't hoping on removing much (if any) material. I know at work when we rebuild transmissions and reuse certain components such as main shafts and turbine shafts, all we do to polish them is soak them in WD40 and take scotch brite pads and wrap and rub . The surfaces turn out looking like they're chrome plated but I am not so sure if this is a good idea on a crankshaft. I did read somewhere that an old leather belt works wonders to just do a basic polish which is all I really need, would you recommend trying that first?
Thanks,
Keith
  #17 (permalink)
Old 05-30-2010, 06:22 PM
I dont know about the leather belt, where is the abrasive? leather belt im thinking is too wide???? Plus how would you get it to turn?? I dont know.
  #18 (permalink)
Old 05-31-2010, 06:46 AM
The recomendation from the chevy power manual is 400 grit emory cloth, lubed with a little kerosene and shoe string.They say to wrap the emory around the crank, tape then use the string to turn the cloth as described above.This is the factory recomendation so it should work.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
First time crankshaft replacment torg57 Engine 36 03-21-2010 10:37 PM
chrome polish for engine SBCfan04 Engine 4 09-27-2008 12:26 PM
Journals are back online Jon Hotrodders Site Suggestions and Help 0 03-21-2005 10:20 AM
Journals are back online Jon Hotrodders' Lounge 0 03-21-2005 10:19 AM
New Site Feature: Project Journals Jon Hotrodders' Lounge 8 01-08-2005 10:10 AM
