How to Properly Read a Compression Test Gauge? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2012, 12:01 AM
Pulling an engine out of an salvage yard
(Big Block Chevy)
I understand how to do the test.
assuming the engine is warm/hot
But What are numbers i should look out for?
What is considered red flag and what is not?
What is are good numbers?
and if the cylinder(s) has low numbers does that mean the piston is bad? is the engine worth pulling?
can the compression be TOO HIGH?
Please help me?
- Hardcore Novice
Old 08-22-2012, 04:54 AM
The numbers should all be about the same.
Stock BBC's are typically low compression so don't expect high numbers. 125 psi is about it.
flat cam lobes and worn out bearings will be the biggest issue, and that will be hard to see at a salvage yard.
Old 08-22-2012, 05:54 AM
Testing a salvage yard motor is not that hard. Have a squirt can of oil with you. Pull all the plugs. Remove anything else that will make it easier to turn the motor over with a socket and breaker bar. Check each cylinder writing down the reading of each. The readings should be within 10% of each other, If you have a low one try and squirt oil in that cylinder and take it again to see if it goes up. If not there is an internal problem. Ask if you can remove the oil pan and remove some main and rod caps to see how much bearing wear. Turning an engine over by hand I doubt you will have any high readings. Usually some yards have a way to set an engine up on a stand and run it for testing. This would be nice. You could see how much total vacuum the engine pulls. An used engine that pulled close to 15 LBS would be good.
big, block, chevy, compression, test
Can you please read this vacuum gauge (Video included) scooty Engine 3 03-11-2012 08:40 PM
compression test sadie00 Engine 4 12-27-2010 08:04 AM
Compression Test stratt134 Engine 3 07-26-2006 01:58 PM
Compression Test Canadian Charlie Engine 11 06-01-2005 09:39 PM
Compression test blockhead Engine 2 11-30-2002 11:22 AM
