to keep it at the same level regardless of how much weight is carries.
What are you doing, building a tanker?
-EATON SPRINGS- can supply you with a set of springs to raise it safely. If it is going to be dragged occasionally, AIR-LIFT makes bags for it. You can pre-load either side.
LINC TOWNCAR used the system you are talking about. Keep it FORD.
