How raise the back of my 62 Ford Galaxie? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2005, 10:23 AM
I would like to raise the back of my 62 Galaxie about two inches. I am going to put on different leaf springs that have 5 leaves first. If that doesn't work I want to try air shocks. If I try the air shocks I would like to use the load leveling system off of a GM car to keep it at the same level regardless of how much weight is carries. I know on my 1995 Olds Aurora the system works very good. Does anyone know if using this compressor would work.
Any suggestions on raising the back of my car are appreciated.
Bobg
Old 04-28-2005, 10:32 AM
It's not recommended, but I reversed the shackles on the leaf springs of my
'61 Ford and it never caused me any problems. I merely twisted them
around with a pry bar. Of course that was 44 years ago and I didn't
know any better.
Old 04-28-2005, 11:08 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Um Hmm
know any better.
Been there done that..about that same time as well..Might try the load leveler air bags from firestone..works on my truck..Some what simpler than anything else I can think of..
OMT
Old 04-28-2005, 12:40 PM
poncho62's Avatar
Wiki Edits: 5
The re-arced springs with leafs added will do it.....................
Air shocks will make the ride rougher..............
Ontario Rodders
Old 04-28-2005, 01:37 PM
aka Duke of URL
What are you doing, building a tanker?
-EATON SPRINGS- can supply you with a set of springs to raise it safely. If it is going to be dragged occasionally, AIR-LIFT makes bags for it. You can pre-load either side.
LINC TOWNCAR used the system you are talking about. Keep it FORD.
Old 04-28-2005, 01:50 PM
willys36@aol.com's Avatar
Wiki Edits: 21
How much lift do you want? Do you want it permanently? Is it to clear big skins or just for a '60s 'rake'? Re-arched springs is the most elegant and engineering-wise sound approach for a permanent rake. Adding leaves will only make the ride stiffer w/o much raise unless you re-arch all the leaves. If you decide to add leaves only add long ones, this will give you a relatively softer ride. Short leaves stiffen the ride significantly. Obviously, air shocks are the best approach for an occasional nose-down stance. How you do it primarily depends on what you final goal is.
Old 04-28-2005, 02:26 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I vote for the re-arched springs.
Disk for 62 Ford Chucks,57 Suspension - Brakes - Steering 0 04-16-2003 06:07 PM
disc brakes for 1964 Ford Galaxie RALEIGHPET Suspension - Brakes - Steering 2 02-16-2003 04:16 AM
The Ford GT is back dmorris1200 Hotrodders' Lounge 10 11-26-2002 12:39 PM
Ford Race Engine BarbWire Engine 7 10-18-2002 11:38 AM
