-   -   How to rebuild a 88 chevy 350 big Block (http://www.hotrodders.com/forum/how-rebuild-88-chevy-350-big-block-30487.html)
gearhead66 12-18-2003 05:50 PM
Im new to motors so i need to know how to rebuild a 88 chevy 350 so i can put it in the scout 2 im restoring
poncho62 12-18-2003 06:11 PM
a 350 is a small block.
Rebuilding a motor is not for amatures, Research by reading up on it 1st.
Rubberman2003 12-18-2003 09:17 PM
You can get this book at autozone, its called overhauling (or rebuilding) your Small block chevy. GREAT BOOK, its a haynes manual, its blue. Should be easy to find.
ricarnell 12-23-2003 02:29 PM
'88 350
Just checked my files on the 1988 350. The aluminum heads on the corvette version of the L98 TP1 350 get raised exhaust ports and revised valve head and seat angles for an increase in flow. They are identified by casting number 10088113. Camaro specific L98's are still equipped with iron heads. Both L98's get the LB9 Camaro (305 TPI with manual transmission) camshaft which increases intake and exhaust valve lift by 0.0011 inch and 0.015 inch respectively, and adds 4 degrees of exhaust valve opening duration. The changes boost Corvette horsepower to 245 and IROC-Z horsepower to 230. Self-aligning rocker arms are introduced on all Gen 1 engines. Throttle-body fuel injection is introduced for 350 trucks. This is the last year of any carbureted 350.
Rubberman2003 12-24-2003 01:51 PM
Gearhead66: did you find anything helpful?
ahuguley 12-24-2003 02:37 PM
You might want to get the following book:
Auto Fundamentals
http://www.amazon.com/exec/obidos/tg...books&n=507846
This book goes into deep detail on how a car works. I tried starting off with a repair manual but was immediately confused with some of the terminology. Auto Fundamentals helped a whole lot.
