Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to remove axle from differential, 1970 C-10
Old 08-11-2012, 06:47 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
that differential should be a "C" clip design. Push the axle ''in'' and C shaped clip on the inner end of the axle is removed. Diff cover must be removed
