How to remove axle from differential, 1970 C-10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2012, 06:24 PM
This is the rear end on a 1970 Chevy c10 pickup. Number is 3817778 11:4, GM 6-70 1 4:1 on the gears. I need to change the rear axle seal, but am unsure how to remove the axle. Any other information on this rear end would be helpful. Pictures I have found don't look the same as this one.
Old 08-11-2012, 06:34 PM
Crosley's Avatar
Wiki Edits: 1659
that photo is not a transmission. It is a differential.
Which do you need information on?
Old 08-11-2012, 06:43 PM
Yeah, girlfriends should not be left alone to post.
Need to know how to remove the axle.
Old 08-11-2012, 06:45 PM
Crosley's Avatar
Wiki Edits: 1659
I edited the thread title for proper information
Old 08-11-2012, 06:47 PM
Crosley's Avatar
Wiki Edits: 1659
that differential should be a "C" clip design. Push the axle ''in'' and C shaped clip on the inner end of the axle is removed. Diff cover must be removed
Old 08-11-2012, 07:31 PM
big gear head's Avatar
High Performance Rear Ends
There should be a retaining bolt that is holding the shaft in the center of the differential. Remove that bolt and the shaft should come out. When you get the shaft out you need to push in on the axle (with the wheel and brake drum removed). Then you can remove the c clip from the end of the axle and the axle will slide out.
This might help. http://www.thirdgen.org/techboard/tr...ing-axles.html
30 spline differential axle or not? 69 C-10 stepside Transmission - Rearend 4 10-01-2010 09:45 PM
Differential/axle questions 69 Grand Prix 60smotorhead Transmission - Rearend 3 01-21-2010 02:59 PM
axle slid out from the differential 59 wagon man Transmission - Rearend 13 01-20-2008 07:30 AM
Remove Front CV Axle Rightytighty Suspension - Brakes - Steering 0 04-23-2007 12:27 AM
Differential Swap/axle concerns hhessig Transmission - Rearend 2 02-07-2005 05:59 PM
