Upper ball joint is held in by four solid rivets, you need to gring the heads off the rivets and drive them out to remove them, the replacements will bolt in using the original rivet locations.
The lower ball joint is a press fit into the arm, you need to rent a ball joint press(loks like a big specialized C-clamp) or have them pressed out using a hydraulic press. |
By the looks of that picture, you need to be careful that the spring doesn't come flying out of there and taking your head off. I know the shock is in there, but that one looks pretty old.
When doing a job like that, I keep the spring compressed by having my jack stand under the lower "A" frame.....I hammer the bottom ball joint out, might need to heat it a little. I then press the ball joint in with the floor jack, using the weight of the car to do it.
Ontario Rodders |
| Separating a stubborn lower ball joint taper | Slipangle | Suspension - Brakes - Steering | 32 | 05-06-2013 01:07 PM |
| Ball joints for MII? | BobbyG-39 | Suspension - Brakes - Steering | 15 | 07-24-2008 04:40 PM |
| Mustang II ball joints problem?? | BobbyG-39 | Suspension - Brakes - Steering | 4 | 10-04-2007 01:31 PM |
| Lower ball joints | tommer2 | Suspension - Brakes - Steering | 6 | 09-09-2007 05:29 PM |
| installing new ball joints | helrazr3 | Suspension - Brakes - Steering | 8 | 06-11-2007 07:20 AM |
