How to remove brazing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2009, 12:34 PM
The top of my quarter panel has a joint that looks to be brazing of some sort? Its copper in color so maybe brass?? How can I safely remove this?
Old 11-18-2009, 03:51 PM
With a torch and a wire brush. Then a 3M ROLOC "Surface conditioning disc" will remove what is left off the metal.
Old 11-18-2009, 03:56 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
If you have sanded on it and it's still copper colored,it is NOT brass.Brass was used generally on tops/sail panel joints,structural joints and IF it IS brass.You best leave it and just clean and filler over it because you'll not find a better joining material.
Pic/s would help.
Old 11-18-2009, 04:14 PM
I haven't sanded on it, just scraped the paint and seam sealer off. Im not sure what metal it is, its just brassed colored. I have to remove it though so I can seperate the quarter panel from the car. Ill try and get some pictures of it.
Old 11-21-2009, 07:14 PM
Is there an outside chance that it's origional to the vehicle?
But if you absoloutly feel that you must remove it, What MARTINSR said is what I'd do.
Old 11-22-2009, 07:56 PM
Yes, it is original to the vehicle and I would like to save one of the panels at the joint if I can.
Old 12-01-2009, 08:11 PM
Took me a while, I kept forgetting to get a picture. Here is a picture showing the brazing I need to remove. The panel I want to save is on the right side.
Old 12-03-2009, 03:50 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
I would cut out what you want to get rid of and use a 3" Roloc sanding disk on a small hand held grinder.
Old 12-03-2009, 04:30 PM
poncho62's Avatar
Wiki Edits: 5
It could be factory....when I worked in an AMC plant in the early 70s, we used to braze certain joints that couldn't be spot welded.
Old 12-03-2009, 05:27 PM
It is factory, that is exactly how it was on the car when they cut the quarter panel off and nothing had been done to the car as far as I could tell.
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
1999 Jeep Cherokee Rear Axle Seals - Help leejoy Transmission - Rearend 2 05-15-2007 07:50 PM
Using a Grinder to remove paint duallybuster Body - Exterior 16 07-30-2006 10:17 AM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
C6 Installation Trucknut Transmission - Rearend 6 01-18-2006 05:01 AM
