How to remove broken screws from torq thrust wheels - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2005, 10:05 PM
Ripped's Avatar
Last journal entry: First RoadCourse Video
The Torq Thrust wheels I inherited for our mustang are in pretty nice shape except that the previous owner had used low grade screws on the center caps. Many have corroded and broken off flush with the wheel.
What's the best way to get them out
Old 12-29-2005, 06:04 AM
this has worked for me:
lay the wheel down, spray with Blaster, tap tap tap with a hammer to work the blaster down the threads, let it soak overnight, spray again and tap some more....patience is the key...let the Blaster break the galvanic bond between the two different metals from wet-hot-cold 10,000 times
Sears/Ace Hardware/etc., #1 "screw out" ($3?), it's a hardened reverse threaded screw extractor for broken screws that fits in your threading tap handle
punch the screw center, drill a 1/16" shallow hole, tap the 'screw out" in to get a bite, turn right, stubborn, drill bigger-go deeper
Old 12-29-2005, 11:16 AM
Kroil is the BEST penetrating fliud I have ever used in 30 years of messing with old cars. It works where others failed.
I would put some Kroil in the holes once or twice a day for 3 or 4 days. Then use a reverse drill bit that is small than the bolts.......drill down and they just back out....worked for me...a couple times....
Old 12-29-2005, 02:45 PM
Duece, dumb question but what store(s) carry Kroil?
I "googled" it and it does sound good....no chain store links came up
thanks' my Blaster can is bout' empty
Old 12-29-2005, 05:55 PM
Originally Posted by red65mustang
Deuce, dumb question but what store(s) carry Kroil?
http://www.jdheritage.net/DeerelyDep...Items/4001.asp
Old farm tractor restorers around here use it and turned me on to it..... I used to make a bunch of parts for them at the machine shop...
The John Deere store here has it....
I prefer the can....squirt type.....less waste...IMHO
Deuce.
Old 12-29-2005, 06:29 PM
Wiki Edits: 31
I think PB blaster is better than Kroil. I'v used Kroil b4, and it works, I used pb blaster and it does work good too, that is all I buy. I know that PB blaster has some additive that is a good rust eater, maby kroil has the same additive?
Torq Thrust D rip offs 68Velle Hotrodders' Lounge 2 04-07-2005 07:30 PM
Tire size for torq thrust II's sicksixseven Suspension - Brakes - Steering 6 03-13-2005 06:55 PM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 03:52 PM
Beware Coddington Wheels! 37cabriolet General Rodding Tech 18 12-24-2003 09:24 PM
Torq Thrust mitmaks Body - Exterior 1 02-15-2003 07:23 PM
