Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how to remove cab off frame....
Old 10-12-2011, 05:15 PM
52fatness 52fatness is offline
I did the jack it up and roll the frame out from under on my'52. You will have to have your supports wide enough to clear the tires when the frame rolls out so you will probably need 4 x 4s instead of two by fours. It still took three people for me to pull this off. I supported the 4xs on old SOLID oil drums. If you decide to try this be careful that cab may be heavier than it looks and can be awkward. Good luck
