Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how to remove cab off frame....
Old 10-16-2011, 11:52 AM
hp246's Avatar
hp246 hp246 is offline
I've done this several times. Once using the method described by 66GMC. I've also used 2 heavy nylon straps worked around the cab. Then used the cherry picker/engine lift. I build a frame out of 6 X 6 with heavy duty caster, and was able to wheel the cab around.
