how to remove cab off frame....
slowly working on a 57 chevy pickup. i have the bed off and the front fenders and nose off. all thats left is the cab which is not bolted to the frame. has anyone taken off the cab by them selves or with one other person. im not working in a driveway or a garage on this project. in fact its behind the garage with limited space and a slight incline haha. reason for lifting the cab is so i can roll the frame out so i can pull the motor and trans before winter and clean up and paint where the cab sits. and roll the frame back under.
what im thinking is i use jacks and lift the cab enough to get two by fours under it and them on blocks just high and wide enough to roll the frame out. or i use my engine hoist and rig it up to the cab to lift enough to make a small wooden frame on blocks and rest the cab back down on that. give me ideas to make this easier, quicker, safer... pics would be helpful. thanks. ill post pics of my project area. |
If you remove the doors it takes off a lot of the weight. Then find 3 other guy's with strong backs and weak minds and have them help you lift it off.Two guy's can do it but it will be work.
at least 3 extra friends and an appropriate amount of beer.
We used an engine lift to take my cab off, which was relatively easy to do ... as the cab was completely stripped. Doors off, windshield and backlite removed, etc.
Screwed an engine lifting (carb stud type) plate onto a 2" x 6" x 8' which we put thru both door openings. Came at it with the engine lift thru the windshield opening. Going back on the frame was done manually, 4 guys and some ramps. Laid the ramps against the frame rail so that the poor buggers that had to cross the frame had a place to set the cab while they jumped over the frame rails. I gotta say, it was a whole lot easier using the engine lift. |
You could try this?
You'll need 1 buddy and a pick-up to do it this way. First thing is remove the motor and trans. Cut a whole bunch of 2x4's 12" long. Lift each side up and place the 2x4's at the 2 corners then you can run a couple of 4x4's across to set the frame on. When placing the 2x4's rotate them as in 2 one way & 2 the other way so they interlock (make sure you leave a big enough gap to slide the frame out without the front wheels on it). Once you raise it up a bit take some 2x6's 8' long under the control arms so the drums don't drag on the ground. Take the front wheels off and lower the control arms onto the 2x6's. Check for clearance, you may have to raise it a bit more. Leave the back wheels on and tie a rope or chain to the back of the truck and slowly pull the frame out. As you do this get a buddy with another 2x4 long enough the pry the frame either way as you pull it out. This way you don't have to raise it to high. Also cut some 1/2" plywood the same size as the 2x4's to level the corners for uneven ground and if you take your time it should come out without a problem. Do what swvalcon says take the doors off remove any weight you can. Doing it this way by raising it a foot and a half is much better than trying to get it up on barrels and it tips over on somebody especially when you are lifting it. This may take a little time to do but its the safest taking in consideration of your work area. Take care and play safe!!
I've done this several times. Once using the method described by 66GMC. I've also used 2 heavy nylon straps worked around the cab. Then used the cherry picker/engine lift. I build a frame out of 6 X 6 with heavy duty caster, and was able to wheel the cab around.
you could use a kids swingset to hold the cab up.Jack up the truck, tie it to the swingset(closest to the A frames for strength) and once tied, lower the frame from under the cab...voila.
I know it sounds funny, just dont use a real flimsy swingset, or make some A frames out of some heavy pipe and do the same thing |
Engine crane if you work solo...
Russ |
All that to say, I'd much rather rig up something so I can do it all solo on the day and hour I am ready. For the sedan delivery I made up a framework of 2x6's, fastened the top to my ceiling joists and then used a chain hoist to lift off the body. However, during the lift-off I quickly discovered that the chain could scratch and mar the body, so while the body was up on stands, I bought a harbor freight winch made for the task. And it worked super when I dropped the body back down on a dolly for painting and then later for picking up the body again and placing it on the chassis. All-in-all I spent far less time making the support posts than I would have spent on the phone trying to organize the work parties needed.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
But no matter how stout the stands, I would advise always keeping the hoist completely fastened to the body as a backup precaution. Dumping a body could be disaster...particularly if you happen to be under it when it goes.
I like this simple but effective solution.
I can't see how that wooden frame is supported in the photos. Did you attach the 2x6's to the ceiling? |
| 1950 truck frame swap to 1980's chevy frame | 1950truck | Suspension - Brakes - Steering | 25 | 01-24-2013 06:13 PM |
| How can I remove 2 door post trim from the post and door frame? | 1964 Oldsmobile 442 | Body - Exterior | 1 | 07-17-2011 04:41 PM |
| 1967 Buick Lesabre convertible Frame or compatible frame | wash64864 | Body - Exterior | 1 | 12-07-2010 09:13 PM |
| replacing a front unibody frame with a tube frame ? (bit long) | lowROLLERchevy | General Rodding Tech | 5 | 04-06-2007 09:49 PM |
| How do remove motor mounts from frame? | In_Style | Hotrodding Basics | 5 | 10-12-2005 07:52 PM |
