Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to Remove a Carrier Bearing
Old 07-12-2009, 07:10 PM
junior stocker's Avatar
junior stocker junior stocker is offline
Are you refering to the "support bearing" for a 2 piece driveshaft? If thats it, it's not too difficult. Loosen the knurled ring from the front shaft and separate the 2 piece driveline. A puller makes removing the support bearing easier, but it can be removed without one, and a little creativity. Be sure to mark all the parts BEFORE separating anything so you can put it back together the same way. Most libraries have repair manuals if you don't have one.
