How to Remove a Carrier Bearing - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2009, 10:55 AM
bosco200's Avatar
How to do you remove a carrier bearing on the Drive Shaft?
Old 07-11-2009, 10:58 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
What are you working on some remove different then others. Cole
Old 07-11-2009, 11:18 AM
eloc431962's Avatar
Wiki Edits: 37
Sometimes they are pressed on the shaft. Cole
Old 07-11-2009, 11:25 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Prob the same truck he's been asking about gearing for:
Originally Posted by bosco200
1972 C20 Chevy and it has a 250 Ci V6 with a 4 speed manual transmision and 4.11 rear end
I doubt it has a V6 engine, though.
Old 07-11-2009, 11:36 AM
eloc431962's Avatar
Wiki Edits: 37
Torch it off. Cole
Old 07-11-2009, 11:38 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I'd suggest not giving bosco any bad ideas... he seems to not know much about vehicle repair and is seeking proper guidance.
Old 07-11-2009, 11:45 AM
eloc431962's Avatar
Wiki Edits: 37
I am sorry crosley, I went back and read all of his post, and maybe he should take it to someone who know how, but if for some reason bosco you try this make sure you mark the old bearings location so you can put it back where it was at before, you can mark it with some yellow marker paint or something like that. Thanks Crosley for pointing this out to me . Cole
Old 07-11-2009, 11:37 PM
prostreet6t9's Avatar
Differential/Driveline
Mark the D/L before you pull anything apart!
Can you post a pic of the carrier Brg? On Some of the early style Carrier Brg's you will need to knock out the U-joint to get to the bolt that holds on the yoke next to the Carrier brg, remove the bolt and yoke. Then you can use a press to remove the Brg. Alot of time these are not a TIGHT pressed fit and sometime even pull off by hand.
If it's the later style the Brg, it will just press off after you seperate the D/L. The later style is a tighter pressed fit and you may need use a press or Brg remover to get it off.
If your slip yoke has a Screw on cap don't forget to unscrew it before you try and seperate the D/L's
I woulnd't suggest using a torch ! If you scar up the surface where the Brg is pressed on,the new Brg will spin on the shaft and you WILL have a premature failure.
Again!!! Mark the D/L Before you seperate the 2 pieces! You want to put it back together the same way to avoid any vibration problems.
Last edited by prostreet6t9; 07-11-2009 at 11:44 PM. Reason: I need to learn to spell!!
Old 07-12-2009, 08:10 PM
junior stocker's Avatar
Are you refering to the "support bearing" for a 2 piece driveshaft? If thats it, it's not too difficult. Loosen the knurled ring from the front shaft and separate the 2 piece driveline. A puller makes removing the support bearing easier, but it can be removed without one, and a little creativity. Be sure to mark all the parts BEFORE separating anything so you can put it back together the same way. Most libraries have repair manuals if you don't have one.
Old 07-13-2009, 04:42 AM
Wiki Edits: 85
I have replaced several carrier bearings by the roadside with hammer and steel punch (or shaft) to drive them off of and on to the driveshaft.
If you are not sure how the shafts go back together be sure to mark them. If you fail to do that, then all you need to do is line up ALL u-joints with each other so they flex in unison. Wrong line up will cause horrendous noise, vibration, and failure in very short order, sometimes in less than a mile of driving.
Old 07-13-2009, 06:35 AM
BOBCRMAN@aol.com's Avatar
If you want to do this job. Here is how the pro's do it.
First separate the shafts. The large knurled collar holds the two shafts together. There is a rubber O-ring inside the collar. This slides off over the splines. Very tight fit and will sometimes break on older shafts.
Most c-bearings are rubber mounted. The rubber is just a molded piece that will pry off with a long bar and some work. Determine front and back. Remove. Then place a bearing pull collar around the metal bearing and press bearing off with a press. A large hammer and chisel will work if no press is available.
Install by sliding new bearing assembly over the splines on the shaft. Then drive it on the press portion of the shaft until it seats against the shaft. I use a long driver. Looks like a piece of pipe with a drive ring welded on.
Replace o-ring and thread collar.
To line up the two shafts for re-assembly. The spline will have a "Skipped tooth" line it up with the grease zerk on the outer piece. Push together.
Old 07-13-2009, 06:45 AM
bosco200's Avatar
Ok thanks I got it off.
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 07:07 PM
carrier bearing lookatme Transmission - Rearend 5 03-22-2006 12:23 AM
rear oil seal help alrobjr Engine 5 01-24-2006 08:12 AM
C6 Installation Trucknut Transmission - Rearend 6 01-18-2006 06:01 AM
1986 or somewhere around there s10 driveshaft angle problems fumplet Transmission - Rearend 10 01-16-2006 10:20 PM
