How to remove heat shield from intake manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2012, 01:08 PM
Absolute beginner
Hello guys,
I need some explanation here.
I have 70'SBC aluminum intake I need to clean. There is heat shield I need to remove (see the picture). Is this metal parts rivets or bolts or screws?
I can grind them but how to reinstall heat shield after that?
Thanks for the help,
Ivo
Old 05-03-2012, 04:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Use a sharp, gradually tapered 1/4" chisel to get up under the edges of the rivets (you might need to grind a chisel down to get the best tip. Don't grind until red hot or the temper will be lost). The rivets I've seen have spiral "splines" on them, so they tend to turn as they come out.
You should replace the shield after cleaning, you can tap for screws or peen/stake the holes to reuse the original rivets (use locktite).
New rivets can be bought, check eBay (click on image below) or Year One, etc.
Old 05-03-2012, 09:52 PM
4 Jaw Chuck's Avatar
I've always used a set of large sidecutters to lift them out, works really well.
— Han Solo
Old 05-04-2012, 07:18 AM
Wiki Edits: 27
horshoe nippers
a pair of horse hoof nippers that both sides are sharp or a pair of tile nippers(smaller) that are sharpened work and are usefull in other places.
Old 05-04-2012, 12:41 PM
Absolute beginner
Thanks for replies.
I removed them with chisel and hammer. It was easy.
Thanks for the help, perfect as always
Ivo
Heat cavity on intake manifold and Heads truckboy61 Engine 4 03-29-2010 03:29 PM
Heat shield? 1953 Homer Engine 2 06-20-2008 04:32 PM
carb heat shield vetteman Engine 5 05-31-2008 12:43 AM
heat shield gawdzilla General Rodding Tech 2 06-16-2004 05:47 AM
starter heat shield camay7 Electrical 3 06-09-2004 01:39 AM
