how remove outer wheel bearing race - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2010, 01:39 AM
001mustang's Avatar
I have removed wheel bearing races using a hammer and a freshly squared punch. Sometimes the races have a slot for easy punch access; no problem.
The outer race from 65 mustang disc hub has no access slot and it is tricky to get punch to stick on the race.
I am transferring some low mileage races and would like to reuse the races and bearings on a different hub.
I have a shop press but can't figure a way to use it for race removal; must hold punch at an angle.
Any trick or tools for removing the hub outer wheel bearing race w/o damaging the race?
Old 10-01-2010, 08:18 AM
delawarebill's Avatar
race removal
i have done a few bearing changes and have never been able to reuse the race.. bearings are too cheap to try and reuse them.. too many chances of dinging it or out of round and then your screwed.... i'd just beat it out carefully and replace them.. but thats my op...
Old 10-01-2010, 10:07 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I have seen hubs w/o acess slots to get the race started, but rarely.
Using a sharpened brass drift, shaped w/a "bologna slice" on the end will usually get it started- if there's some lip to get a purchase on. After you get the race out, I'd suggest you grind a few access slots into the hub for 'next time'.
If that won't work, you'll need to go in (after the hub has been thoroughly degreased) w/a Dremel and grind an access slot on at least two sides to get it out w/o distorting it.
I would tend to agree that reusing the bearing race isn't the best idea, though- but that said, I have done the exact same thing before. After the race is pressed back into the spotlessly clean and deburred hub, be sure to check the bearing for smoothness.
Old 10-01-2010, 01:16 PM
001mustang's Avatar
thanks cobalt,
Cut a couple access slots in hub...sounds like a good idea.
I plan to make access slots small as possible 180 degrees apart.
I don't suppose it will significantly effect hub balance since imbalance near center of rotation and mass of material removed is relatively small?
Old 10-01-2010, 01:40 PM
001mustang's Avatar
hub w/ races removed
64 1/2 mustang disc hub w/o access slot outer race.
Hub has access slot inner race.
ID:	48566   Click image for larger version
Old 10-06-2010, 08:27 AM
001mustang's Avatar
new races w/ old bearings?
I have brand new inner and outer races.
I have low mileage (maybe 5000miles) like new USA wheel bearings.
I've always changed races and bearings w/ no problems.
My dad normally changed bearings but not races w/ no problems.
Will the used bearings likely seat in the new races OK?
Old 10-06-2010, 06:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
They should. But I'd rather keep the bearing and race together, if they've been run as a set- if they're in good condition.
Outer cam bearing 19nova69 Engine 8 05-23-2010 07:32 PM
Outer wheel housing R/R 72 Monte Carlo Rad Ray Body - Exterior 0 08-22-2003 10:44 AM
Gm Wheel Bearing Problem scott011422 Suspension - Brakes - Steering 6 07-11-2003 06:41 PM
steering wheel bearing for 72 chevy any one know where to find one? 72 chevy elcamino Engine 2 10-13-2002 05:18 PM
remove mcgard wheel locks with no key sideman Hotrodders' Lounge 8 03-25-2002 03:16 PM
