How to remove paint from the car's exterior - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2007, 12:02 PM
To my surprise as I was leaving the office, I found my car splattered on the exterior with white paint on the door and parts of the front of the car.
I tried taking it off with water and soap but did not work. It appears like someone tripped and accidentally splattered paint on my car and the sidewalk , but they left no note.
Is there a way to remove it without harming the car's surface? I tried with my fingernail and the tiny ones came off but not the big ones. HELP PLEASE!!
Old 07-27-2007, 12:14 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Arge,
I am wondering if this is Latex based or not? Apparently you think it is (using Water)-there will be other ideas, but I wonder what about a product like Goof-off-some people don't think it works, but in certain situations it has for me-
WD-40, Bug and Tar Remover and Rubbing Alcohol also comes to mind-if it's not Latex based, try some Laquer Thinner-
Old 07-27-2007, 12:21 PM
latex paint or not
I am hoping it is latex paint...but I really can't tell. Since it did come off in the tiny spots, and when I touched one of the bigger spots it was still a little fresh in the middle part and the texture felt latex-like.
would acetone also work? thank you.
Old 07-27-2007, 08:41 PM
Try using WD-40. I once drove over yellow street line paint that someone had dumped on the street. Had it on the lower front fender, rocker and rear quarter. A lot of it
the WD-40 worked but it was a lot of work. That paint is very think.
If you have latex splatters it should come off more easily.
mike
Body - Exterior "Tips of the Day" Jon Body - Exterior 11 09-07-2007 11:29 AM
Intresting, maybe, new cars with the same exact damage......... MARTINSR Off-Topic 0 12-30-2006 01:20 PM
Sherman Williams Clear Coat Failing < 3 Years? DeJarnett Body - Exterior 33 12-11-2005 10:39 AM
hard paint to remove adrock430 Body - Exterior 2 09-27-2005 09:28 PM
Masking Door Jams etc. 36ford3window Body - Exterior 9 02-06-2005 08:17 AM
