How to remove pilot bushing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2004, 10:22 PM
70bird's Avatar
Smile if you know Jesus
Last journal entry: Waiting for a tranny
Is there an easy way to remove a pilot bushing without taking the bellhousing off. The Lakewood bellhousing is held on with about 25 bolts. The only way to get to all of the bolts is to pull the engine. I'm replacing my Richmond T-10 (it couldn't hold up to the 502) with a Tremec TKO-600 in about two weeks and feel it is a good idea to replace the pilot bushing even though it only has about 3000 miles on it.
Old 07-26-2004, 10:27 PM
New Member
The pilot bushing, or do you mean the throwout bearing?
Old 07-26-2004, 10:56 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
you're double posting, check your other post for answer.......joe
