How to remove pilot bushing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2004, 10:27 PM
70bird's Avatar
Smile if you know Jesus
Last journal entry: Waiting for a tranny
Is there an easy way to remove a pilot bushing without taking the bellhousing off. The Lakewood bellhousing is held on with about 25 bolts. The only way to get to all of the bolts is to pull the engine. I'm replacing my Richmond T-10 (it couldn't hold up to the 502) with a Tremec TKO-600 in about two weeks and feel it is a good idea to replace the pilot bushing even though it only has about 3000 miles on it.
Old 07-26-2004, 10:29 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Fill it with grease and jam a main shaft into it, it should pop right out.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 07-26-2004, 10:31 PM
poncho62's Avatar
Wiki Edits: 5
Pack the hole full of grease and hammer a rod the same size into it. The displacing grease will force it out.
Ontario Rodders
Old 07-27-2004, 01:50 AM
A socket that fits into the bushing hole & a long extension will work, but don't hit it so hard you damage the extension.
Old 07-27-2004, 08:38 AM
Im trying to have an idea!
ive used soap shavings, i think its less mess.
Old 07-27-2004, 08:54 AM
onebadmerc's Avatar
I need a bucket of arc sparks
The grease method works great on solid bushings but it won't work on the roller type. You will have to use a puller if you have a roller pilot bushing. If the puller doesn't work, which I found out last winter, you will have to break the roller bearing bushing up and remove it in pieces. I used a hammer and chisel and chiseled it out piece by piece out.
Old 07-27-2004, 09:04 AM
70bird's Avatar
It is a roller. I'm going to attempt the socket tip as soon as I finish my coffee.
Old 07-27-2004, 10:11 AM
troy-curt's Avatar
Be sure and wear safety glasses, especially if you go the chisel method.
Troy
Old 07-27-2004, 10:42 AM
4 Jaw Chuck's Avatar
Slide hammer on the difficult ones and greased shaft on the easy ones.
Outlawed tunes from outlawed pipes
