how to remove rust from under car floor?
I have my 38 Chevy apart.I'm new at body restoration work.Frame has been sand blasted and painted.Now I want to clear the body under side of rust before putting the body on the chassis.The body is on a low cart.I was thinking of sanding, brushing and treating with acid, but all this is over head work.I was thinking of sand blasting, but if I want it done right I usually have to do it myself and have no sand blaster.Again working over my head anyway.How do most of you do this type of job?I'm not a POR15 believer (sorry).
Cisco |
thanks, that's just the kick I need.It has to be cleaned and I'll have to do it.I'm going to clean any sealer and have a go at it, but probably call a sand blaster guy come do it. Thanks really , Cisco
You can always do what deuce did.
Cisco,
If you hire someone to come over and sandblast your car, make sure they have experience (that you can verify) blasting sheet metal on cars. Ask what media they recommend. If they say, "Sand," then thank them and find someone else. Actual sand will warp body panels, and I wouldn't suggest trying to get away with using it even on the more rugged bottom of a car. Thanks, PeterM |
I have been very critical of sandblasting sheetmetal myself and I have told how I ruined my decklid and door so many times it is almost embarrassing to mention it again BUT he is talking about the underside of this thing and sandblasting this area is ok and is done all the time. Sandblasting the floor area, under-hood and door posts will not hurt a thing but you guys are right and I should have warned about blasting unsupported panels such as doors, hoods, fenders, etc since these will be destroyed due to warpage. Sandblasting is the most effective way to remove rust from this floor area although some of the other media will work too and is safer. Also just one more word of caution, whatever media is used wear a GOOD respirator ESPECIALLY IF YOU USE SAND!
Where I mentioned "under-hood" I meant the engine compartment NOT the hood itself. Last edited by oldred; 04-21-2006 at 08:05 AM. |
sand blast
i sand blasted under my 68 mustang. i bought a cheap siphon blast gun with hose. i took a small container about 6" high by 12" square and filled with sand. the car was about 18" high off the floor. i ducted tape plastic onto the car and to the floor, leaving the rearend open for entering. at the front i installed a hose for my shop vac. i cut about 18" of hose from the siphon kit to use for my exhaling to keep from steaming up my hood lense. i set the blast pressure at 80 lb. i used a 4" brush to sweep up the sand and screened back to the container. i used about a 1/2 bag of sand. the floors did not warp because i used a siphoned blaster which i purchased for $10. it was time consuming, it took me 4 days. but turned out great. hope this will help you.
Read, Simply ingenious
Thanks guys.Actually the blaster guy I'm after advertises for soda blasting, but I've heard stories of it being hard to clean after.I'm thinking media blast.Any thoughts on either?
I have my car at a backyard hot rod garage.He is a certified mechanic , but he and his brother (bodyman) do not encourage me to do the job I think I should, which is get the rust off.They say POR15 the car.They think if I blast I won't have any floor left and I think if thats the case then the car needs work.The car has pin holes in the trunk and front cowls are gone.I'd rather spend time on it now than have to redo it in two years.I'm just fishing here to see if others really go to this extreme to refinish a car. Is acid etch primer a good base after blasting?I can get in in spray cans and get the car coated fast after blasting. Thanks guys, Cisco. |
Cisco, I agree 100% POR 15 may have it's place somewhere but if that floor is rusty enough so that sandblasting would leave holes then POR 15 is not going to fix it. I will not say the stuff does not work and some people swear by it but what about the trapped rust in seams and other places? And the fact is if you just cover the rust you will still have a rusty floor. Good luck with your project and if you stick with doing it right you will be glad you did.
Duece has some guts rolling that body on it's side. My Son and I built a flip over stand for his Nova and had it shot blasted earlier this week. The shop charged $200 and was done in two hours. They blasted the interior, floor, cowl, and inner quarters, trunk, and jambs. Rustfree now and in epoxy ready for new quarters.
[IMG] [/IMG]
I don't believe you should use an acid etch primer on blasted steel. defignately not a metal prep. Think the blasted surface would make it hard to neutralize the acid. But if it is blasted there really wouldn't be any reason to use an acid product on it. Thier purpose is to eat away at small amounts of rust and etch the surface, being blasted should take care of both of those. etch primer is a 1k product, epoxy primer is 2k and will cure chemically. I would epoxy prime it as soon as possible and epoxy also will seal the surface. blasted metal tends to flash rust quickly. bodywork can be done over the epoxy, many etch primers recommend to not use any filler over or under them and would need an epoxy over the etch primer if doing so.
Cisco,
Read the thread in the forum on the SPI website: http://spi.forumup.org/about156-spi.html The short version is that at least one manufacturer (SPI) does not recommend soda blasting due to problems with paint adhesion afterwards. Thanks, PeterM |
| "Basics of Basics" Photographing your car. | MARTINSR | Hot Rod Art | 89 | 03-31-2009 02:53 AM |
| "a little over" turns into $4500 over for paint job | bullheimer | Body - Exterior | 128 | 02-06-2006 08:57 AM |
| Rust Dissolver versus Rust Convertor? | 66GMC | Body - Exterior | 9 | 11-06-2005 05:48 PM |
| how would you make it legal?? | spooki | General Rodding Tech | 8 | 08-31-2003 09:16 AM |
| Some rust in the floor pans. Suggestions? | 327ImpalaSS | Body - Exterior | 12 | 02-01-2003 09:24 PM |
