How to remove spinning flush rivets? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2005, 09:31 AM
New Member
I have a dash that's riveted to a dash frame with rivets that are smooth/flush on one side. On the other side where you would drill the rivets out, the dash comes out/up, so that I can't get a grip with pliers or anything to stop the rivet from spinning so I can drill it out. Is there a tool or some way to hold these rivets so I can drill them out?
Old 06-26-2005, 09:54 AM
I use a dremel tools with either a small cutoff wheel or carbide bit. It spins fast enough to compensate for the rivet spinning a bit when your cutting. In other words your not going to spin the rivet 5000 to 10,000 rpm like the bit will spin. Takes about 5 seconds to cut them off.
Old 06-26-2005, 03:25 PM
New Member
I would have never thought of that. I have a Dremel sitting around, I'll check it out. Thanks!
Starter Keeps Spinning Checy_Guy Electrical 10 11-25-2004 10:28 PM
question on how to remove factory stereo from 94 gmc sierra shane7643701 Interior 0 02-28-2004 07:15 AM
transmission flush APACHEMAN Transmission - Rearend 23 08-17-2003 12:02 PM
Flush Brake fluid CptBil Suspension - Brakes - Steering 5 10-18-2002 08:31 AM
drilling out rivets norms37chevy Transmission - Rearend 5 04-12-2002 07:03 AM
