How to remove a stuck speedometer drive gear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2012, 12:30 PM
rusthater89's Avatar
I have the tailshaft off of my th 350 trans. I pressed the clip down with a screw driver but no matter how much yanking the gear will not slide off the shaft.
A book I have tells me to tap it with a 1 1/4 wrench, which I do not have.
Anybody have any advice?
Old 08-06-2012, 02:18 PM
Use a crescent wrench. Or a pipe wrench. Or anything else that will slide over the shaft.
The Following User Says Thank You to lmsport For This Useful Post:
rusthater89 (08-06-2012)
Old 08-06-2012, 03:59 PM
Thanks, will attempt again tommorow. I do not have an adjustable wrench that is big enough but these big pliers I have may work.
how do you remove a partially stuck valve in a 4L60e valvebody? old yukon Transmission - Rearend 7 01-31-2011 10:17 AM
Remove Flywheel Stuck on Crankshaft SS66chevelle Transmission - Rearend 5 06-25-2010 12:58 PM
saginaw speedometer drive gear buicfrank Transmission - Rearend 3 04-11-2010 12:15 AM
Ford AX4N Speedometer drive gear Argess Transmission - Rearend 4 03-01-2010 10:13 AM
700r4 speedometer drive gear tobiahr Transmission - Rearend 3 01-23-2008 11:22 AM
