how to remove tach drive from distributor ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2005, 11:12 PM
Hi All,
I recently picked up a stock GM distributor with the mechanical tach drive take-off. I know it's a mid sixties Corvette app, but I don't know specifically what year as the ID band is missing.
Anyway ~ I want to go through the distributor before running it and have been told I have to unscrew the brass tach drive take off before I can remove the distributor drive, but how ?
The threaded brass connector has a flat blade screwdriver slot across it's face, but since the tach drive cable enters in the center of this connector, there is a big gap in the center where there is no slot, and consequently none of the flat blade screwdrivers or impact bits are wide enough to reach across this gap.
I thought I was clever by taking stainless flat washer & cutting it in half, so that the edge made by the cut was wide enough to reach across to both sides of the slot on the connector. That part worked, but the washer started to bend before the connector started to turn.
I've tried strap wrenches on the outside of the connector, but it's dia. is so small and it is located so close to the underside of the distributor base that that didn't work.
The only other thing I have thought of is chucking up the wides flat-blade impact bit I have in my drill press, put the distributor in the drill press vise, and turn the bit with a wrench while applying downward force to keep the bit from jumping out of the slot. (I got the idea from an old picture in an article about servicing a generator, where the field coils where held in the case by big flathead screws and the extractor tool looked like an arbor press with a screwdriver blade on the end.
Any other suggestions are greatly appreciated ~
Daren
Old 08-23-2005, 01:49 AM
Update: how to remove tach drive gear from distributor
I got it out tonight, here's how; ~ ground down one side of a stainless flat washer to effectively create a very wide flat blade screwdriver tip. Then I cut a slot in a 3/8" bolt from the top of the head, through the head and into the shank nearly the diameter of the SS washer when measured from the flat edge. I then tapped the washer down into the slot in the bolt so that the only part of the washer that stood out above the bolt head was the flat edge I ground, about 1/32". Chucked up the bolt (ground edge down) in the drill press, the distributor in the drill press vise, a wrench on the bolt head and applying downward pressure so the home-made wide flathead screwdriver tip wouldn't jump out of the slot, I put a little pressure on the wrench and the tach drive connection came loose almost immediately.
Glad I did too as I found the bottom bushing in the distributor was really chewed up.
Daren
Old 08-23-2005, 06:10 AM
MI2600's Avatar
Member# 3287
Glad to see you got it done. Don't you just love those times when you need that special "something" to get that "whatever" out. Success is exhilarating!
setting points on sb chevy frackster66 Electrical 14 03-22-2008 11:33 AM
Tach Problem MI2600 General Rodding Tech 2 11-06-2004 10:51 AM
Sun Tach. Wiring Help 383vette Electrical 4 10-02-2004 02:00 PM
Distributor Timing Problems ottomatic777 Engine 3 06-30-2004 01:54 AM
Distributor Clock position (long) Screwy Lewy Engine 7 07-16-2003 01:25 AM
