Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to Remove these Cab Mounts?
Old 07-15-2013, 10:19 AM
oldBodyman oldBodyman is offline
you can use an air chisel or torch at the 90% shoulder to remove the rust and leave the flange, this will give you more access to grind the spot welds. anyway you do it, it takes time and really messy. ear plugs to keep the rust out of your ears.
