Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to Remove these Cab Mounts?
Old 07-16-2013, 07:17 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
I'm not real big at sitting under something and throwing a shower of sparks all over everything so I would use a sawzall starting with the bolt then jacking up the cab a littleand cut out all of the mount leaving just the lips then drill out the spot welds...be sure to pull back the carpet if there is any BEFORE you weld the new ones in.and be sure that whole cab is on stands before you get started
