How to Remove these Cab Mounts? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-17-2013, 05:20 AM
deadbodyman's Avatar
Wiki Edits: 11
I dont know if you really want to remove the cab,I dont think I would Sure thats what you'd do if you were restoring it but if this is your daily driver and you need it, do one side at a time you can jack the cab up quite a bit to get clearance you need for working and you dont have to worry about it squashing your legs its impossible,the cab can only go down about an inch, when the floor hits the frame thats as far as it'll go... Being your a newbie I think you'd have more chance of getting hurt by removing the cab....Dont forget things likethe steering colume and wiring harness will need to be disconnected also...why make a simple litte cab mount job into a big drawn out deal...Of coarse its totally up to you but if it were me I'd just jack up one side ,replace he mounts ,jack up the other side and replace them ,bolt the whole thing down and drive away. still it might take about a week to get R done
  #17 (permalink)
Old 07-17-2013, 07:54 AM
This is true Mike, if ONLY the cab mounts are being changed you are very right. If it's going to be more drawn out, then removing the cab would make things easier. But yeah, that may be a serious overkill.
  #18 (permalink)
Old 07-17-2013, 08:31 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
If it's just a daily driver, leave it on for sure. Drill out spots and plug weld from the top as was already mentioned.
I assumed this to be a rod/restoration project.
  #19 (permalink)
Old 07-18-2013, 05:08 AM
Wiki Edits: 11
Originally Posted by 777funk View Post
Check these pictures out. I'm sure I could knock these out with an air chisel but I'm not sure that's the best way, I'd sure hate to destroy the floor or inner rocker panels.
What's the best bet to get these out? Also, the bolts, how would I remove these? I'd guess they're rusted on good and the broken off mount parts would spin if I hit them with an impact. Maybe I could hold them from rotating with a vice grips? Check out the pics:
A 90 something dodge truck ????
  #20 (permalink)
Old 07-18-2013, 06:33 AM
2nd Gen Cummins truck (95). You've seen this before?
To my eye, it looks like the welds are right at the seams in patches. Maybe I'll be able to see better once I get the undercoating stripped.
Speaking of undercoating... this truck looks as if it was undercoated and the donor I have (96 1500 V6 Ram that I picked up for $500 for the bed and body parts) is only in paint (no undercoating) and the cab mounts are almost perfect. Could be a coincidence.
  #21 (permalink)
Old 07-27-2013, 12:53 PM
Would it be unwise to cut off the rust on the existing cab mounts (i.e. most of the mounts until you get right up to about an inch from the floor board) and then just weld in new metal to the old mount surfaces to fab up a new mount?
  #22 (permalink)
Old 07-27-2013, 04:25 PM
Wiki Edits: 11
Theres only a few spot welds to drill out,why not do it right its easier...first off the new piece wont fit right and you'll be struggling the whole way and it'll never be right...if you can drill a hole with an electric drill you can drill out a spot weld...and do it right...dont worry we wont let you screw it up...you can do it...
  #23 (permalink)
Old 07-27-2013, 04:35 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Yep. Just pull the seat and carpet and drill from the top.
  #24 (permalink)
Old 07-27-2013, 04:49 PM
Thanks guys, I was thinking about fabbing them from sheet metal and I figured the parts that attach to the body (curves) would be difficult. Thats why I considered just welding to those existing parts. But it sounds like that's not a good idea?
  #25 (permalink)
Old 07-27-2013, 04:54 PM
Wiki Edits: 11
yeah you gotta pull the carpet up anyway.If theres a double layer of steel there and you need to drill them from the bottom ,you can make it real easy by cutting out the outrigger from the frame ,replace the mount then weld the out rigger back on its a lot fasterand easier than working around that thing...just dont loose it. or them
  #26 (permalink)
Old 07-27-2013, 04:59 PM
Wiki Edits: 11
Making them yourself wouldnt be wise ,replacing them will be hard enough...If you want I can get some good used ones and send them to you...
  #27 (permalink)
Old 07-27-2013, 05:25 PM
Thanks for the offer DBM! You guys are helpful! I needed a new bed for this truck so I bought a spare truck with a bad engine and it has good mounts. So I guess I will need to pull those off and weld them in. I've never done this so I am trying to find the best/easiest way. Sounds like taking those mounts would be the best bet. I also didn't want to tear that spare cab up since it's a good cab and someone else could have a need for it possibly. But the mounts are there so I might as well take em.
  #28 (permalink)
Old 07-27-2013, 07:17 PM
poncho62's Avatar
Wiki Edits: 5
Why dont you just use that good cab? Probably easier than trying to change the mounts
  #29 (permalink)
Old 07-27-2013, 07:53 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
X2
  #30 (permalink)
Old 07-27-2013, 09:23 PM
I would if I could but the donor truck is a single cab and the keeper truck is an extended cab. But the mounts that are bad are the ones that are on the single cab.
how to remove cab off frame.... unearthly57 Body - Exterior 22 11-15-2011 07:01 PM
How do I remove in-cab Gas Tank 69 C10? coreyboothproject Hotrodding Basics 4 11-05-2010 07:41 PM
cab mounts and springs 46highboypu Suspension - Brakes - Steering 0 11-02-2010 10:43 AM
Making cab mounts indyracer Body - Exterior 0 04-15-2006 09:07 PM
Cab mounts Gearhead forever Body - Exterior 7 01-28-2004 10:38 AM
